So, Sample srewed his motor up a little bit ago.
Discussion in 'The Garage' started by Sample, Feb 18, 2004.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Yep, stabbed the throttle and it stuck to the floor. Engine revved up, I dropped it into nuetral, revved way up, I shut it down. Popped the hood to find my tranny kickdown cable came off the throttle arm on the carb and jammed the throttle cable. I fixed the two cables, fired it back up and off I went.
    Now it hits on 6 or 7 cylinders. All cylinders are sparking so what the [darn] did I do to it?
  2. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    Re: So, Sample fawked his motor a little bit ago.
    Maybe the truck now hates you...and it's playing sick until you sell it to someone else? Either that or you busted something and it's time for an Izuzu or Kia...
    Rene
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Compression test? you could have little pieces of ring in your oil pan. Good indication is if your oil smells like gas. Could also pull valve cover to watch rockersand make sure you didn't flat spot the cam.
  4. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Rene
    Probably does hate me, I hate it too. Now if someone would just give me about $800 for it.
  5. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Well, the oil definetly smells of gas, but it doesn't matter anymore. I started it up and heard the worst metal clanking sound I have ever heard in an engine. It ran for about 3 seconds then died. I did even want to start it up after that.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    May still be a good core though , don't throw it out.
  7. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    I won't throw it out. It will probably just sit in the backyard in the K5 until I decide to mess with it again.
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Probably threw a rod or wrist pin or something... /forums/images/graemlins/crazy.gif
  9. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Would a aftermarket rev limiter (like a MSD) have helped in this situation? I thought there was a factory rev limiter.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Rene
    Probably does hate me, I hate it too. Now if someone would just give me about $8.00 for it.
    Did I read that right? You want eight dollars for it? /forums/images/graemlins/whistling.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No factory rev limiter. It'll just keep going and going, ask me how I know.
    Now the MSD box on the other hand, that thing works great for throttle junkies like me. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  12. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Yes and no,,,,A rev limiter will protect the engine from running away but even if you "free rev" an engine things can still break.The internal stresses placed on a "loaded"
    engine at a given RPM are entirely different than on an unloaded engine.
    I run a rev limiter for 2 reasons,first I
    don't have to watch the tach when I'm flooring it thru mud holes,I set my shift light 200 rpm below the limiter and notch it up thru the gears when I see the light.
    Second
    reason is if I break some driveline part the engine won't free rev till I reach the kill switch.Iv'e seen lots of people tear up good engines just because they sound good at high rpm's. If they ever looked at a curve chart they would see that most engines loose horsepower and torque after a certain RPM.
    Setting your rev limiter and keeping the engine within the power band is the correct thing to do. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  13. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Id bet money on bent push rods.
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Another vote for bent pushrods. Pull the valve covers and have a look. Once they bend they can jump off of the rocker arms. /forums/images/graemlins/eek.gif If you find that, then also look closely at the top of the corresponding lifter to see if the retaining ring popped out, along with the top cap of the lifter. If the lifters look OK then put some good pushrods in it and see how it runs. /forums/images/graemlins/cool.gif
  15. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I pick "[darn] it up"... do I win a prize? /forums/images/graemlins/thumb.gif
  16. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    How about what ever I pull out of the oil pan? /forums/images/graemlins/peace.gif
  17. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It might be quicker to just pull the valve covers and check the rockers. Maybe you got lucky and just broke one.
