So what are you suppost to do AFTER a roll over?
Discussion in 'The Garage' started by jjlaughner, Apr 20, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    List of things to check or change after a roll over....
    IE Pants /forums/images/graemlins/histerical.gif, then check the oil and fluids.... what else /forums/images/graemlins/ears.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Check to see if your kids are alright... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gifHere we go again... /forums/images/graemlins/ignore.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Turn the truck off immediately. Check and see if everyone is ok and grab fire extinguisher. Check to make sure there is no gas leaking. Flip it back over check all the fluids and refire.
    You must turn the engine off for fire reasons and an FI motor will run upside down and you will blow the motor if you let it run that way.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would pull the plugs and get the oil of the cylinders before you fire it up... /forums/images/graemlins/waytogo.gif
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    roll it back onto all fours /forums/images/graemlins/dunno.gif
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    We didn't do that to Denver75K5 (TJ's) truck after it was flipped over and off a big rock it landed on when it came back on all 4's. Fired up and ran fine. /forums/images/graemlins/dunno.gif
    Harley
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Well, if you want to get technical about it
    1. check to see if there's any injuries
    2. check for fires and kill engine
    3. roll back over(controlling it, so it doesn't roll again)
    4. get oil out of cylinders.
    5. top off fluids
    6. Start engine
    7. Make sure nothing else is broken
    8. mop up fluids on the ground
    9. other stuff I didn't think of... /forums/images/graemlins/grin.gif
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Get a bigger hammer?
  9. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I usually just go WOOOOOOO HOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!! F*&K YEAH!!!!!!!!!!!!!!!!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  10. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Sometimes you don't have to do that part. I've seen it happen both ways. I know two weeks ago when Toby rolled at Hell's Revenge, he had some oil in a few cylinders. But, I do it anyway just as a precaution... /forums/images/graemlins/grin.gif
  11. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ] /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I'm kind of lazy /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif so i will probley skip that step unless it was upside down for more than a few minutes /forums/images/graemlins/tongue.gif
    What do you do to get the oil out? /forums/images/graemlins/confused.gif
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif I'm looking forward to that part /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
    /forums/images/graemlins/ignore.gif /forums/images/graemlins/whistling.gif
  14. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Mine was upside down for about 10 to 15 minutes and I just started her up and drove her to a flat spot. She was about 1/2 a quart low on oil. I lost more 90wt out of the top of the tranny than I did motor oil. I scooped it all up out of the trail and put it in a garbage bag w/ all the glass... you don't want to leave a mess behind.
  15. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Pull a plug, disconnect the ignition so the engine doesn't start, and crank it over just a little. Stand clear of the engine, whatever's in the cylinder will shoot out fast! You use the same procedure to get water out of the cylinders when your hydrolocked...
  16. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  17. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Harley
    True, but we DID need to add a quart of oil so it would show up on his dipstick /forums/images/graemlins/yikes.gif
    Chris
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    Let Tecton know about it and ask him for his opinion. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  19. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  20. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    [/ QUOTE ]'
    lmao /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
