So what did I break?
Discussion in 'The Garage' started by thesaint, Nov 29, 2005.
  1. thesaint
    thesaint Registered Member
    Nov 13, 2003
    6
    San Diego, Ca
    Was just down in Baja on our annual THXGVNG trip (my fav holiday!: one more turkey off the street!:)) did the whole trip in 4hi, went down to 4lo to back up a slight grade into my campsite and . . . BANG! click click click. :(
    truck would still move but hops a bit and you can see the dshaft jump teeth. I thought i shaved a few teeth off the ring gear (stock 12bolt) but pulled the cover to find no damage (couldnt see the pinion but no pieces or evidence in case or lube) came out of the canyon and up the lake bed in 4hi and did the highway and home in 2hi with no evidence of damage or recurrence of above symptoms.
    could i have snapped something in the low side of the Tcase? I thought 205s were bulletproof :confused:
    Does this sound common or like anything anyone has experienced?
    Thanx.
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    sounds like you stripped the splines in the slip yoke on the drive shaft.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    If the only problem is with 4LO, maybe the range gears in the T-case are stripped. The first thing I would check, though, is that the linkage is actually engaging you all the way into LO range. It could be as simple as that.
