So when you tip a 465 on its' nose......
Discussion in 'The Garage' started by justhorsinaround, Jun 12, 2006.
  1. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    .....is all the gear oil sposed to leak out or should there be a seal that would prevent said same?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    You mean tip it so the input shaft is pointing down? It shouldn't leak if that is the case, there is an input seal. The rear of a 465 is sealed using a gasket between it and whatever transfer case adapter is used. If the input is pointing up gear oil will leak out the back if no t-case is bolted to it.
  3. justhorsinaround
    Sep 16, 2003
    6,798
    Yea I was afraid that was goin to be the case. Since the input shaft is captive what does it take to put a new seal in?
  4. 1977k5
    May 26, 2003
    9,992
    130
    As I recall, there is an aluminum housing that holds the seal. Unbolt the housing, remove the housing (with seal), replace seal, re-install housing.
  5. justhorsinaround
    Sep 16, 2003
    6,798
    Okey dokey. As soon as I get the mess cleaned up I'll have to look into that.
    Thanks.
