So who makes the best front shackles for an '86 burb?
Discussion in 'The Garage' started by Czechsix, Jan 3, 2007.
  1. Czechsix
    Czechsix Registered Member
    Aug 14, 2006
    84
    San Diego, CA
    I'm in the process of upgrading my 'burb and one of the things I need are some new front shackles, heavier duty than the originals, or the light duty replacements that are on it now. Front end on this truck is heavy due to the cummins swap.
    So who's got the best design out there?
    I'm tempted to just go to National Spring and see what they have, but there's gotta be tons of you guys that have figured this out already.....
    Some specifics on the truck:1985 Suburban Cummins 24V +NV4500+NP205+Chelsea PTO, TSTMP3, VanAaken, Edelbrock gerotor pump, Isspro pyro/boost/fuel gauges, remote fuel filters, D60 front, 14 Bolt FF rear, Detroit lockers, 6" lift, 35x12.5x16.5 BFG MT, 10K PTO winch, CUCV brushguard, 6m/2m/220/440 radios
  2. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
  4. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    Add a second vote for both. You can't go wrong with either one. I have the ORD with greasable hardware.
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    Gravel Maker also makes bas ass shackles. the ORD's are 1 3/4 wide, not sure on the DIY's, the Gravel Maker's are 2 in wide and made of Hi strength strucural steel which is stronger then cold rolled steel which is what I am pretty sure everybody else uses. all Gravel Makers stuff is made of this type of steel. all are 3/8 thick.
    my burb will get my set of ORD shackles but my Blazer will get my set of Gravel Makers. you cant go wrong with any of them. just pointing out the differences.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I run the ORD's, but like they said, any of the 3 should be great.
  7. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    you can make some yourself.
    3/8" strap cut to length with holes drilled in it
  8. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    yourself, some steel, a drill, and a grinder.
