So, you are starting a VERY steep decent and your engine dies. How to stop?
Discussion in 'The Garage' started by Scott A, Jul 8, 2004.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    This happened to me and my brakes would NOT hold. So, I had to ride it out to the bottom (about 200 feet).
    So with no engine power what holds your truck the best on a steep hill?
    A. Line Lock
    B. Transfercase Brake
    C. Emergency Brake
    D. Throw it in park /forums/images/graemlins/blush.gif
    E. ??
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    With a manual transmission this is not an issue.
  3. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    yeah, becuase you can use engine compression and that low first gear, right?
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Fix your brakes before putting yourself in that situation. /forums/images/graemlins/doah.gif
  5. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    Yeah, I should adjust my brakes. I don't think the drums in the rear are stopping too good /forums/images/graemlins/blush.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not only can I, I do, on a regular basis.
    If you're riding the brakes on a steep downgrade with 50:1 or more crawl ratio, you're on a pretty scary downgrade. /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif
  7. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    A. Line Lock
    C. Emergency Brake
    E. ??
    None of the above; you need to remove the automatic transmission and install this: http://www.high-impact.net/transmission_and_gear/nv4500.htm
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Screw that, just get a doubler, does the same thing and is cheaper.
  9. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    NV4500 is more useful to me than a doubler...and would cost me about the same $$.
    As for stalling on steep hills, get FI or diesel, then all you have to worry about is losing oil pressure.
    Rene
  10. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Throw your wife in front and use her as a wheel chock /forums/images/graemlins/ignore.gif
  11. mrk5
    Apr 20, 2004
    12,338
    1,045
    Northern Colorado
    Don't throw it in park, you'll just break the parking pawl. (Experience? Hmmmm, I wonder? /forums/images/graemlins/thinking.gif)
    IIRC, with hydoboost there is a little nitrogen canister that is supposed to give a little breaking if the engine dies. But that only helps if you have hydroboost system.
  12. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i remember someone was making 12volt vacuum pumps
  13. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: So, you are starting a VERY steep decent and your engine dies. How to s
    I don't have one here at work, but I do remember seeing those advertised in the back pages on many magazines. /forums/images/graemlins/k5.gif
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    There were also FACTORY vacuum pumps run on 12 volts
    Clicky
  15. Ryan B.
    Jul 18, 2001
    5,693
    CA
    interesting! Thanks for posting that link!
  16. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    Clicky
    Very interesting /forums/images/graemlins/smile.gif
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I won't be doing it yet, doing my transfercase, but would like to check those out. There has to be thousands of those cars sitting in yards to pirate a pump from. Sounds real simple too . If one of you get one, post up how you mounted it. /forums/images/graemlins/k5.gif
  18. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    If I had an automatic,I'd shift to low,and slow it down as much as possible,then if it was evident your going to crash,I'd put it in reverse at idle,and then use the throttle to spin the wheels backward--tough on the drivetrain,but better than dying or crashing!.
    And you guys with diesels,or gassers with hydroboost--make sure you have a new power steering belt,and all the hoses and the pump are in mint condition--any of them fail,you've got NO brakes OR power steering--and wet pants! /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif
  19. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    cummins powersteering pumps are gear driven!
  20. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Just switch to manual brakes then its not an issue /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/usaflag.gif
