so...
Discussion in 'The Lounge' started by beater_k20, May 7, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'm confused again.
    i bought the 92 C1500 2 months ago, original plan was to drop it, 4/6. a couple days after i brought mine home, the neighbor guy comes home with one... 4/6, on stock wheels, just like i wanted to do.
    then i come across this website... www.offroaddirect.com
    considerably cheaper than ORU's SFA conversion kit, and right in the price range with dropping the truck.
    so my dilemma comes from the neighbor having a lowered shortbed, and seeing lots of them around. i kinda want something different. while there are lots of lifted shorties around, none are SFA, so i'm leaning that way.
    any advice to help me resolve this situation?
    BTW, i'm thinking TPI 383, 700R4/SYE241(clocked), Ford HiPi D44, 14FF, 7" of lift, and 37" MTRs. ah, and 4.88 gears.
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    The SFA swap sounds genius. Do it.
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Do it. BTW that Blazer looks sweet with the conversion. All it needs is a top chop and it would be baddass.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I've been considering the swap for my '95 C1500. I'd like to see some pics of a converted 2wd first, though. My friend just SAS his '96 Z71... the brackets gave him 6" of lift and he used 6" springs for a total of 12" of lift. He had some 37's and they rubbed bad, so he dropped down to 35's and they still come close. Do you mind trimming?
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yes, i mind trimming, but i'm not beyond a set of bushwackers. i could likely solve a bunch of problems by kicking the front axle out 1.5" with a zero rate, and ditching the stock bumper for a tube bumper.
  6. divorced
    Jul 20, 2004
    5,115
    Ya, I forgot about zero rates, they would help a lot. My friend used a Chevy D44 in his because he refuses to use Ford parts... but I think a Ford axle would work a lot better. Another friend has an '03 2500HD with a 6.0 and 5 speed manual with a Ford D60 in the front sitting on 36" Iroks... ya, it's awesome
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i like the idea of the Ford front axle, because it would put the transfer case shifter in the stock location for an 88-98 truck, allowing me to make the install look completely stock. wont be trail riding with it, but playing in mud and sand is a definite possibility.
    my real motivation for building it is that when i was a senior in high school we had to write down 20 life goals. we then stuck them in a self adressed, stamped envelope, and gave them to the teacher. she sent them out in '04 (5yrs after we graduated). i recently rediscovered mine. one of my goals is to drive something to my 10 year reunion that i built.
  8. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    What kinda transfer case does your buddy have in his truck? And what kinda SAS brackets did he use?
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hahah! What kinda 4x4 company puts a picture of a truck with no front drive shaft on thier website? :haha: :haha:
  10. divorced
    Jul 20, 2004
    5,115
    The one with the '96 used ORU brackets. He still has the driver drop factory t-case, so he just has a big 2 wheel drive now. He plans to get a 2wd 4L60E and use his divorced 205 from a dodge, unless he can find a t-case from a late model sub or blazer that is passenger side drop and has the VSS... but then he needs a high $$$ high angle drive shaft because the Chevy front is low pinion.
    The '03 used Fabritech brackets and a Ford hi-pinion D60. His front output for the t-case was a slip yoke design from the factory, so he needed to get a SYE so he could use a regular style CV shaft. His set up works flawlessly as far as the 4x4 goes, but he has a problems with the bearings loosening up all the time.
    Both of these truck gets ran hard and jumped quite often. the '03 has a track bar, and one time he jumped it the track bar smacked the aluminum oil pan and cracked it... luckily for him, he can weld aluminum, but he still had to take the pan off to do it.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its rumored that there is a hi pinion 60 in Illinois... we'll see what happens there.
