Socket size for air conditioner nut
Discussion in 'The Garage' started by driney, Dec 4, 2005.
  1. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I have an 89 GMC van that I need to get running before I leave on my annual wheeling trip. (No I don't wheel the van!) Anyway the air conditioner compressor is locked up and evidently the bearings are out of the clutch. I have the puller for the clutch but I can't get a socket on the nut on the shaft. It seems a thinwall 9/16" socket will almost go on, so my thought is maybe it is 15mm, but the only 15 mm sockets I have are too thick walled to fit. Before I grind a socket down can someone tell me if that is what I need. I checked at the two parts stores that were open today, but they were as clueless as I was.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    No deffinate answer but almost every accessory bolt on my 87 is metric so it is prolly a safe bet.
    Ira
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Try using a 3/8's-drive socket. They're a bit thinner than the 1/2 inch drive. I replaced the compressor on my '91 S-10 this summer and didn't have any problem getting a socket to fit.
