Sodium Filled Valves
Discussion in 'The Garage' started by fireplug, Mar 1, 2007.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    This is a new one for me. I'm curious what the performance value is as well as the fiscal value.
    There's a motor for sale that seems obviously overpriced to me, and the sellers only real 'defence' is the sodium filled valves. What would you say they were worth?
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Mmmm... salty. :D
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Na...
    thats imposible ;) :D
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Sodium filled valves are about $25.00 each.
    Sodium filled valves are only found on the exhaust valve and it's purpose is to help keep the valve cool to prevent them from burning when used in an abusive or demanding application.
  5. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Hehe so I can assume this 'GM crate' with 'only' 33 000 on it was abused?
    The guy is asking slightly more for this motor than a dealership is a warrantied crate 350 and seems determined that his motor is worth it. :confused:
    Next...
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    What engine are we talking about anyway? AFAIK GM did not use sodium filled valves in any of the SBC or BBC's ever. Well, maybe the 366 and 427 TD engines but not for light duty cars and trucks.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've got a '59 and '63 Triumph motorcycles with sodium filled valves from the factory.....not exactly a modern performance thing. As said, it's to do with cooling properties.
  8. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    not needed in a truck environment without high repeated rpms such as road racing
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    At least some LS1's (maybe even LT1's) have sodium filled exhaust valves.
  10. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    I (obviously) don't know much about them, but since researching a bit I've gleaned, that yes this is old tech, originally for air cooled engines. As an example a lot of aviation info came up in my searches.
    That said, both big and small block motors were associated with them, though I didn't gather whether they were stock that way, with the exception of the Corvette LS7?
    This one in question is a small block 350.
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    My grandad's 1962 2 ton Ford had sodium filled exhaust valves in it's 292. They're usually pretty obvious b/c the stem diameter is huge, instead of the normal 11/32" or 3/8" they are ~1/2"+, but note that the stems are usually stepped down to use stock keepers & retainers so you need to look btwn the valve spring coils & not at the tip.
  12. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    Sodium-stellite valves..
    I've run into those valves often on air cooled motors, like Wisconsins and VW's,and in industrial engines like Onan's and Continental's....they supposedly don't "burn" as easily as "regular" valves would..
    One word of caution!..DON'T attempt to "grind" these valves on a valve grinder!...I learned the hard way they can EXPLODE if you get them hot enough,and go too far with the grinding,exposing the layer of sodium!..:eek1: --
    We had one blow up while grinding the valves from an International 345 bus motor at the auto parts store's machine shop I worked at!..it scared the crap out of us,and we were lucky none of the shrapnel got us in the eyes...:doah:
  13. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    You want a REAL wake up call through water on it afterwards!
    Note: that is some serious sarcasm, DO NOT do that! :D
  14. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    The GM Fast Burn heads have sodium-filled exhaust valves in them. So, any crate motor with the FB heads will have SF exhaust valves.
    Basically, the stem is hollow and is approx. half filled with sodium. At operating temperature the sodium is molten and bobs up and down inside the stem as the valve opens and closes. Since molten sodium conducts heat well it speeds the transfer of hear from the valve head to the stem, where it can be conducted away through the guide and into the cylinder head, thus keeping the exhaust valve head cooler. A cooler valve will last longer, but just as important it helps prevent detonation.This is important in stationary, marine, and truck engines that run under full load for prolonged periods. You can make a longer lasting valve by using better materials such as stellite or Inconel, but it will still run red hot which makes detonation more likely.
