Soft brake pedal
Discussion in 'The Garage' started by 1985K20, Apr 21, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    I just got my rear brakes done yesterday, i put new shoes + springs, cleaned everything up good and finally adjust them up nice.
    I know im getting better braking now but my pedal still soft...i bled the brakes like it should be done too :dunno:
    Front rotors and pads are to replaced but would that explain my soft pedal??
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Assuming everything is stock size, air in the lines or soft flex hoses that also need replacing.
  3. carolina k-5
    carolina k-5 Registered Member
    Jan 20, 2005
    58
    columbia, S.C.
    not sure what you meen by "soft". if you meen spongey, yeah ya still might have air in the lines. also double check for leaks. especially rear wheel cylinders. if you meen it has too much travel in the pedal you can adjust that above and behind the pedal. let me know how it turns out.
  4. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    ok i found my spongy pedal problem: left rear wheel cylinder leaking :)
    but i still find too much travel on pedal :frown1:, i hear there's an adjustment for brake pedal? Where is it located at? on the shaft goin into booster :confused:
