soft liftspring
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, May 16, 2001.
    i am from germany an i ride my blazer since 15 years. i installed a 2,5 " rancho lift kit . The front springs too rough. I took off one leave per side and put in a plastic insert for lower friction. All this didn't help.
    Can anybody tell me from whom manufacturer i can get soft and comfortable frontsprings.
    thanks for your help in this case.
    Klaus form Nuernberg Germany
  1. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Hi Klaus....I think Rancho makes the soft ride springs. I've read about them before....Rancho comes to mind.
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Tuff country springs are soft too
    Brent
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Ranchos do ride rough in my opinion. EZ rides from Tuff country are about the softest you can buy... the regualr Tuff countrys are pretty soft too... just remeber the softer the spring the more body roll you will have.. There is a chart in the technical section w/ the spring rates. Next softest are probably the Superlift superirdes or BDS.
    1987 Chevy K5 Blazer- 350 TBI
  4. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Anyone got any experience with soft springs causing braking problems (pulling) or loose front ends? I was told a long time ago that my springs were a factor in my loose front end.
  5. plk33
    plk33 Registered Member
    May 10, 2001
    13
    northern Minnesota
    I have an 87 1/2 ton Suburban and I have been considering new 4" lift springs. I need a soft ride because of a very bad back. Are the tuff country ez ride 4" springs going to ride better or worse than the stock springs?
