SOFT LOCKER? What is it?
Discussion in 'The Garage' started by jjlaughner, Mar 20, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    http://www.4wheelparts.com/product2.asp?imseqn=1183&occlass=DETL&cat=Drivetrain
    With the new soft locker at virtually no additional cost, you can reduce engagement noise levels. Special conical insert dampens engagement levels.
    DET225S-10 GM 14-bolt 10.50" - all ratios $415.93
    SO IS THIS BETTER THAN A REGULAR DETROIT?
    Less clunking tells me less friction, still have traction but it turns better? Anyone run one in a 14bolt?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well the SKU (part #) for 4wheelparts starts out DET we know it is a Detroit brand by Tractech. http://www.tractech.com/Products.htm I do not see that name on their site. Must be new or they(4wheelparts) changed the name. /forums/images/graemlins/k5.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    It's a locker that is soft /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's a "new design" of the Detroit Locker. Those special inserts just prevent the locker from making you think that the transmission just fell out on the road as it engages. /forums/images/graemlins/thumb.gif
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Thats what I'm wanting to avoid /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    top
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    this replaced the standard detroit for the 14bff. It was a newer better design.
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    THATS what I want to hear! /forums/images/graemlins/waytogo.gif
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    There are not any "friction" devices in a Detroit Locker. Just square teeth that engage and disengage as it locks and unlocks. Many people believe that a locker works like an open diff and then only "locks" when needed. In reality it works just the opposite. Most of the time a locker stays locked, just like having a spool in the diff. When one tire tries to rotate faster than the ring gear, the locker will completely disengage the axle on that side and let it freewheel to somewhat provide a differential effect. When the speed of the wheel and ring gear match up again, the locker will re-engage. On earlier Detroit Lockers the teeth sometimes really slammed when engaging. The new Soft Locker just added the inserts that soften the blow by engaging the teeth just slightly more slowly.
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    That makes sense /forums/images/graemlins/thinking.gif When I said friction I meant the surface to surface connection of the locker (square teeth as you put it), snapping back closed and relocking causing the the "big bang" did I drop my tranny feeling /forums/images/graemlins/doah.gif
  12. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I run a soft locker in mine. It is just as durable as the original, has no extra moving parts and such. The main change is the spring rate. They use a lighter rate spring that allows the plates to pass each other easier, and when done it returns to locked with less force. My dana 60F lockright is way louder than my 14FF. I have only really heard the detroit a dozen times or so in the last 7 months.
    If any thing above is wrong let me know and I will correct it.
