Soft top material
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Dec 10, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am going to make a soft to for my K5 but can't find the material. What is a cheap material that is also easy to find and somewhat waterproof?
    Houston, TX
  2. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    My soft top is made of vinyl. Next spring I am making a bikini top for my 75 out of cordura. Kinda spendy, but you will never wear it our. Also, you may try canvas (like the military trucks and seats), convertible top material, cordura or vinyl. I believe any of these materials will do the job. Also, I would visit a boat shop and invest in stainless steel snaps for the body and top.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Can backs are made out of canvas. Kayline tops are some kind of vinyl, just like Jeep tops.
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
  4. SKI-'84K5
    SKI-'84K5 1/2 ton status
    Oct 11, 2001
    175
    Imlay City, MI
    when you do this I would like to know, I am thinking about doing this myself, no matter how many times I mess up it's gotta be cheaper than a can-back or kayline, and either way my wife probably won't ride in it anyways.
  5. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Cegusman &amp; SKI-84,
    I have been thinking about it also for quite some time and I have found that at Hardware stores(Home Depot, Lowes)
    They have Canvas tarps in all kinds of sizes, For the K5 I think that a 10x12 would work. I have looked at the CanBacks design and thought of ways to make it work for cheap. I went and bought electric condut(sp) and I'm makeing a U type frame with runners of angle iron for the mounting surface to hold the frame and a place to put snaps. the Conduit cost $15.00 and the Tarp will cost about $50.00(they are Drab/Army Green)
    Good luck in what you decide, I figure about $75 bucks and if it dosen't work then o well. Later KEN
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  6. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    I used vinyl from a boat/uphoulstry shop. It cost me roughly $60 to make the soft top. It's a relatively simple design. I used 'male' snaps with metal screws around the cab. On the bed rails I used a 4"x6' piece of oak using the same bolt hole for the top and on the tailgate I used Heavy duty Velco that had very sticky tape on the backside. To keep the top from leaking around the cab I used weather striping. Never leaked yet! Here's a picture. This picture is after I tore it apart. I have new plans for the top.
    <a target="_blank" href=http://community.webshots.com/user/nicksm79>http://community.webshots.com/user/nicksm79</a>
  7. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Can Backs are actually made from Sunbrella which is a fabric caommon in the awning trade. Its waterproof and UV resistent. Canvas wont cut it unless its well treated with some kind of waterproofing.
    James
    jimmy79@shaw.ca
  8. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I went to an army surplus store and got my top materal. I got a 10 x 8 water proof tarp and it was about $45. are you going off some type if fram?
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am not going of of a frame.
    Houston, TX
  10. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Did your top ever leak? I am in the process of making a soft top for my K5 and would like to know how loud is your top on the Hw or down the road? I was trying to make mine out of a cut up hard top, tarp and a snap kit.
    thanks brett
  11. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    No my top never leaked. The only time I got water inside, it was because I was pressure washing the mud off. On the highway it is loader than the hard top but with mud tires its loud regardless. Besides, its well worth being able to go topless anytime you want or cover up if it starts to rain. I also never had a problem with it blowing off. I had the truck over 100 MPH and the top was just fine. One suggestion, Don't buy cheap material! You will end up replacing it with in a year or 2 if its not taken care of. I made that mistake only once.
  12. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Thanks for the info!!
