Soft top security
Discussion in 'The Garage' started by chevyjeff, Apr 1, 2004.
  1. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    Since topless is the way to go now that summer is almost here, what security measures do you guys run when you have a soft top or no top. Reason for asking is some p.o.s. mangled my door the other day to get a 300.00 stereo. Should have left it unlocked and I would be better off.
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    The best thing to do is have great insurance! there are tons of thing you can do to help keep your things yours. Talking with your nabors is always a good idea. keep an eye out in the naborhood. A good alarm helps, that have microwave sensers (since we're talking about topless), ignition kill, pager helps if your a light sleeper. Keep the place that you park well lite. Can't get this throught to people enough. Light is something most thiefts dont like they may be seen.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do you mean like a boat alarm? I see those Dock Cop alarms, look like car alarms but work on open air boats. Also my mothers husbands dad had a trick, he wired two momentary switches in the starter wiring. One was on dashboard , one was hidden under carpet next to dimmer switch. To start truck you had to turn truck on, hold down floor switch and bump the dash switch to start it. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i've been in mental anguish over this one. I have a soft top, but fear that some fk will mess with it. I know someone will mess with it here in CA. As mentioned above, I guess insurance is the key as well as alarm. I may install it and see if I can sleep at night /forums/images/graemlins/doah.gif
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I remembered another Idea. I saw in an audio mag once where a guy took a early 80's factory 8 track am/fm radio and cut the front off to make a custom radio cover. No one would bother with the truck then I wouldn't think /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  6. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
    I plan on a tuffy console for the radio and cb. Does anyone remeber that thing that would go around the column and lock? think it was made by mcgaurd or someone. We all know how easy it is to steal a gm car w/ a screwdriver
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    you can also use a starter cut out switch or a battery disconnect switch if you dont mind reseting your radio stations. /forums/images/graemlins/thumb.gif
  8. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    most peoples truck here you have to do stuff like that anyway
    tap the gas, fiddle the switch, rattle the wire, ect
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Here is a microwave sensor:
    Invisibeam® Field Disturbance Sensor
    Generates two invisible detection fields around your vehicle, offering either a Warn Away® response or full alarm. Great for convertibles, trucks or any car.
    it is a add on to most alarms.
    More info:
    The sensor uses an RF field to detect objects of sufficient mass that move within a defined area. An object intruding the “outer-zone” triggers the 1st stage output or “warning-zone”, such as siren chirps or the 516T voice. Intrusion into the “inner-zone” triggers the alarm.
  10. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    you can also use a starter cut out switch or <font color="blue"> a battery disconnect switch if you dont mind reseting your radio stations. /forums/images/graemlins/thumb.gif </font>
    If you don't want to re-program your presets, run the memory wire on the deck strait to the battery. Just put a fuse on it befor conecting to battery.
    Here is a good tip for the guys that disconnect their battery alot and dont want to loose their preset. go to Radio Shaft and pick up a 9volt battery plug. connect positive side to radio memory wire, the other gets end is grounded. Connect a 9 volt battery. Memory stays intake while battery lasts. I had a switch in my old truck to keep the trucks's clock from draining the battery down..... My mechanic in Southern CA was shocked when he reconnected my battery after rebuilding my trany and my stations were still locked in. a week and a half with the battery disconected...
  11. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
  12. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    1) good alarm.
    2) no stereo
    3) removeable steering wheel
    4) removeable tcase shifter (leave it in N when not in use)
    5) brake pedal lock
    6) big chain run through ur rim and around the frame
    7) big dog
    8) big gun
    9) keep it in the garage and add a light switch to its power circuit so you can cut it at night
    10) get "the boot", like paid parking lots use so a vehicle cant go anywhere.
    11) motion-activated lights/vid cam system for the garage.
    12) add lojack or onstar to your rig.
    presto, secure.
    j
  13. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    1) good alarm.
    2) no stereo
    5) brake pedal lock
    7) big dog
    8) big gun
    presto, secure.
    j
    How long would it take you to get to work everyday if its your DD when you have a chain, you have to re-install the shifter and steering wheel. /forums/images/graemlins/rotfl.gif
  14. RClivin
    RClivin Registered Member
    Jan 20, 2003
    23
    Santa Cruz CA
    Dont forget the Big Doodies that that big dog will make lol
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Haha good point /forums/images/graemlins/thumb.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
