Soft Top w/o Rust Problems?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rooba, May 11, 2001.
  1. Rooba
    Rooba Registered Member
    May 8, 2001
    28
    Portland, OR
    I have a question about going topless. The good thing is that here in Oregon it stays pretty warm most of the time... The bad part is that it's usually raining at the same time.
    My concern is that drilling holes for the snaps will cause more access for rust to grab hold and I'm wondering if anyone has had that problem or knows of a good way to make sure it doesn't happen.... outside of drilling then repainting the whole thing. All comments appreciated.
    Thanks,
    Cpt. Rooba
  2. MikeS
    MikeS Registered Member
    Feb 15, 2001
    20
    Charlottesville, VA
    I've had a soft top on my truck for about 6 years. No problems with rusting around the snaps. Before I install the screw in part, I squeeze some silicone into the hole and onto the back of the snap. Seems to seal it up real nice.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ditto!! I second that! The best way is to squirt a dab of sillycone on each screw/hole while inserting the screw snaps to the frame. Works great!! I hate my hard top and will most likly never put it back on!
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  4. Rooba
    May 8, 2001
    28
    Portland, OR
    Thanks!!! I really appreciate the tips!
    Cpt. Rooba
  5. Quetzal_SJ
    Quetzal_SJ 1/2 ton status
    Feb 20, 2001
    123
    San Jose,Ca USA (BAY AREA)
    Hello Burt,
    Seeing how you mentioned that you would most likly never put your hard top back on would you be willing to part with it? I am in need of one. I plan on waiting out the whole Kayline mess. So I can get a fast trak.
    Thanks Lico
  6. Crushergmc
    Crushergmc 1/2 ton status
    Mar 17, 2001
    181
    Oregon
    I'll trade you my excellent hard top for the 1/2 top you have.
    "KEEP IT DOWN"
    70 Jimmy, 454, 2wd
    56 GMC, Big Window
