soft top with a roll cage
Discussion in 'The Garage' started by mostwanted, Apr 11, 2006.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Does anyone run a full cage (4 posts in the back) with a soft top? I would like a soft top that somehow incorporates the cage for attachment. With extra bracketry I don't think that I would care to see a jungle jim of tubing with a cage and brackets too. BTW, pics would be cool.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    489
    Grand Rapids area
    This is a good idea as long as you never want to go back to a hard top.
    You would still need some crazy bends or "extra tubes" because the roll cage will have to fit inside the bedrails (and maybe the cab) and you want the soft-top to sit flush with the outside of the bedrails and the roof.
    Or if you don't mind an "undersized" looking soft top, you could just have some material cut to fit whatever roll cage you have.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    This past weekend I went and bought a bikini top/metal attachment piece for a Cj7 for $80. It fits over the back seat passenger perfect......this is the best pic I could come up with.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    The metal attachment piece or whatever it is called was screwed into the top of the cab, then the top slides into it and is rolled back and tied off with straps at the back.......does that make sense?
  5. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I've been working this out on paper too lately. I picked up a used Kayline/STC top. It's the snap version, though I don't think it would make any difference.
    Anyway I've only test fit the top, but I think you could pretty easily make it work if the cage fits within the confines of your hardtop. If not, picking one up used would probably be worth getting the main pieces (the header and rails) and having the rest custom sewn.
  6. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    I am curious who would custom sew one? maybe a awning/ canopy company? Yes, I will build my cage within the confines of the hard top. I am quite a way from having the cage built, but I am working things out in my mind so I can get some sort of plan of action.
  7. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Yeah sounds familiar! I have a full convertable roof and windshield and doors sitting in the shop too. But for the time being I figured I'd go this route.
    I'm thinking about starting with two factory rollbars one in the stock location and the second at the rear. I recently read a post stating that there is a factory rear roll bar but I've never seen one. For me the roll bars are really more for a roof rack attachment than rollover protection.
    A marine shop will be able to help you out or send you in the right direction.
  8. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    I would feel a bit safer for my family if there was a cage while running with a soft top.
  9. linksvu
    linksvu Registered Member
    Jan 7, 2006
    89
    Littleton, Colorado
    Is there any additional word about the "factory" rear roll bar? I am very interested as well. I do not feel comfortible wheeling with a soft-top and without a cage back there for the fam.
    Anyone seen a kit out there?
  10. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    There is a factory roll bar, my 82 K5 came with one. It was located all the way back by the tailgate and is made of 1 3/4" tubing I think. It is attached to the floor in 4 places and actually looks pretty strong. Sorry I can't post any pics because I took mine of when I put in the full roll cage.
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I have the factory bar for my '73. It does not bolt to frame. Main hoop bolts behind front seats, and has support struts on each side running back to the wheel well. Enough to possible save you though. It's stting in my backyard since I installed a full roll to frame.
  12. linksvu
    Jan 7, 2006
    89
    Littleton, Colorado
    I assume that fit under the hard-top as well as a soft-top, right? I would love to be able to find one of those....
  13. bajaviking
    Apr 10, 2002
    752
    Baja
    Yes it fits under the hardtop, if all you want is a rollbar behind the backseat it probably wouldn't cost too much to have it made by someone if you tell them that you are going to paint and install it yourself. If you bolt it to the floor remember to sandwich the floor plates.
  14. linksvu
    Jan 7, 2006
    89
    Littleton, Colorado
    Hmm... good point. All I would like to do is tie in the roll-bar behind the front seats to a rear roll-bar with enough room for the hardtop and a soft-top.
    Maybe I will look around and see if I can find someone to put one together for me.
    Also, you are saying it is best to have the plates on the bottom of the rollbar bolted to the floor boards as well as a plate under the floor boards to bolt to, correct? That makes sence...good thinking:bow:
  15. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Yeah that is good info thanks I wouldn't have thought of that and it's goin in this weekend! I love this site!
    I would also love to get my hands on one of the rear factory rollbars. I checked E bay and the "For Sale" here on CK5 with no luck. A cage would be nice but I imagine it would get pricey quick without welding skills.
    I had a 4x4 shop price out a custom bumper (all I want is a tube with a receiver) last week, they wanted $1000 ! Yeah right, I try to be polite but it's hard to keep a straight face when you know you are being taken advantage of.
  16. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,021
    621
    Pueblo, CO
    Look at the boneyards. I've come across a couple of factory rear bars. Tired to buy the first one I saw, but they had just sold it. Next one I saw I jumped on it for $25. Just mocking into place the factory rear bar is just above the rear window opening. The way it sits, it has two short support bars (same size tube as the main hoop) that go forward and bolt to the backside of the rear wheel tubs. So the rear bar sits at least 3" in from the gate and a inch or so in from the side/bed rail.
    I'm planning to do what you are thinking of. Tie the two facory roll bars together with additional tubing. Then I'll get a front cage kit from smittybuilt to protect up front.
  17. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    Can you come up with some pics?
  18. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Just a quick update. I tried installing the front rollbar from a '73 - '75 into my '76 and it will not fit. It is close and would work with some minor adjustments in the stock location, but would require even more in the rear of the truck because it interferes with the gas filler neck. I'll post pics in a couple of days to show the tolerances.
  19. ZooMad75
    Apr 5, 2003
    1,021
    621
    Pueblo, CO
    [​IMG]Here's a pic of the rear roll bar. Don't have it installed yet.
  20. linksvu
    Jan 7, 2006
    89
    Littleton, Colorado
    It looks like that bolts to the floor as well as the back of the wheel well, is that correct? Looks good though...
