Soft tops and exhaust fumes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blackwidowk5, Mar 13, 2001.
  1. blackwidowk5
    blackwidowk5 1/2 ton status
    Dec 1, 2000
    107
    Richmond, Virginia
    When ever i roll the back window down in my blazer and drive around the exhaust get sucked into the truck. I was wondering if this happens with soft tops too. If i put a soft top on will i be smell my exhaust constantly? It's a '79 by the way.
    thanks
  2. dyeager535
    26,982
    191
    how is your exhaust routed? In the stock location, even with duals, i had no problem with that on my '83. You drive with the front windows down too I assume?
    Dorian
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    well i have dual straight out the back, and it comes in with the rear window down. when i have front windows down not as much comes in.
    but when the top is completly off, i dont smell them AT ALL!!!
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  4. yellco89
    yellco89 Registered Member
    Mar 9, 2001
    13
    Arkansas
    I have the same problem, been told that the small wing that come factory on some Blazer/Jimmy's will stop the exhaust fumes due to redirecting the airflow over the top. That doesn't answer the soft-top question though.
  5. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    that rear thing you are refering to i think is called either a "rear air dam" or a "rear spoiler"
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I have the older style Kayline and a single tailpipe in the stock location on the right side (used to have duals). I get fumes with the rear side windows closed and the tailgate window open, but not with the rear side windows open. Pretty much like when the hard top is on.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Man you guys are driven in style, I get fumes in the cab even with the window up. You lucky dogs.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  8. belly
    belly Registered Member
    Mar 10, 2001
    14
    Brisbane, Queensland, Australia
    I've got a single 3 inch dump pipe (on 45 degrees) behind the passenger rear wheel, when the back window is down I don't get any fumes, with dual pipes, exiting both out the back and sides it use to makes your eyes water!
  9. blackwidowk5
    Dec 1, 2000
    107
    Richmond, Virginia
    Thanks for the help. I have duals by the way. But does anyone know about the soft top question?
  10. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    the soft top will be just like the hard top if all you have removed or rolled up is the rear window, if you also remove the side windows there will be enough air flow to keep the fumes out.....but those chevy fumes are all part of having a K5.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  11. Topher
    Topher Registered Member
    May 12, 2000
    81
    North Texas (DFW)
    Blackwidowk5 - FYI with the Skyler soft top (that makes the truck look like a pickup) I get no fumes in the cab at all (unlike with the hard top on and tailgate window down).
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The factory sent the pipes out the side of most (all?) wagons, Blazers, Subs, SUVs, etc. that have rear passenger areas and rear openings (in particular opening windows). This is because when you push a box through the air, a low pressure area is created behind the box. In a vehicle, the exhaust will be pulled into this lower pressure area and into the passenger compartment. That is why rear exhaust is not good on these types of vehicles. Even with the window up, the pressure differential can pull in exhaust (including carbon monoxide) around the door/gate openings (have you checked the seals?). With a side exit exhaust, the bad stuff is carried away with the slip stream sliding by the vehicle. Even with the exhaust out the side, many vehicles come with a warning not to drive with the rear window open because of the potential for CO poisoning.
    The moral of the story? Most of the time, the factory actually did have a reason to do things the way they did. [​IMG] Just like all the clips that people leave off and then wonder why there wires and lines break. Anyway, I'm guessing that some people will point out factory options that violate this "out the side" rule but the facts and the physics remain valid.
    IMHO, you should run the exhaust out the side fore or aft of the rear tire for 2 reasons.
    1) It is less likely to get crushed closed on a rock
    2) Less danger from exhaust fumes.
    On an open truck, obviously 2 does not apply...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
