soild axle swap into ifs suburban
Discussion in 'The Garage' started by MountainJeeep, May 4, 2006.
  1. MountainJeeep
    MountainJeeep Registered Member
    Jan 5, 2006
    12
    Centennial, CO
    ok first of all State Farm Insurance rocks!!!!
    Secondly I am thinking about converting a 96 suburban into a family style rock rig.
    My biggest concerns are mating a sm465 to the engine (dunno if later model engines work like the old 350's) and removing the independant front suspension and swapping in a solid axle (dana 60).
    I will get my insurance check later this week, and hope to start buying all the parts and pieces for this project asap.
    any info on the sas would be appreciated.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the sm465 will bolt to the engine jsut like anyother manual transmission, just make sure you use the right flywheel because you have the newer engine with the one peice rear main seal
  3. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    The 465 you want isn't the common one everyone has-- the case is the same, but the top cover is different. I have the 465, adapter, and 241C driver drop transfer case out of an 89 1-ton IFS available, but you might consider an NV4500, and then the transfer case depending on which front axle you get.
    Jimbo
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    damn you! suddenly i'm reconsidering dropping my C1500.:mad:
    :haha:
    its good to see ORU finally has some competition. any idea what the lift from the brackets alone will net you? (ie- ORU brackets give 3" of lift, 6" springs = 9" lift)
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    IIRC, the conversion brackets net you 3"-4" of lift.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    2"-3"
    2" from firsthand experience.
