Sold to CK5 Member !!
Discussion in 'Complete Vehicles' started by seattle73k5, Aug 8, 2006.
  1. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    Sold to CK5 Member good luck with it have a blast and take lot's of pictures so I can see it's progress :D
    Pictures upon request
    1973 Chevy Blazer
    NO SMOG
    I bought this truck last year from the owner of the company that makes custom mufflers (Coffin Mufflers). He originally bought it for his son.
    He lifted the Blazer and put the NEW 44” boggers on it, rebuilt the transmission and transfer case. He sold it to me because his son kept getting in trouble with it.
    I bought it and in the next 6 months built it up to what you have listed below, everything listed below except for the engine is NEW with less than 200 miles on it unless otherwise noted.
    I finished installing the axles and everything else on it 2 weeks before shipping out to Iraq for the second time.
    I even have a few boxes of NEW stuff I have not yet installed.
    This is not a show truck this truck was made to play.
    BODY
    NO RUST
    NO dents on body straight and clean
    Drivers door has dent from when I bought it previous owner backed a delivery truck into it ( I have a replacement door left for Iraq before I could swap it out)
    Underside of the rig and Frame were coated with POR-15.
    INTERIOR
    Interior is good not new by any means but good for daily driver or offroading without worrying about ruining it.
    Custom Grey Tweed interior
    Buckets and Bench from newer Blazer
    Power windows ( no cracks in glass even rear tailgate window works)
    Power Locks
    Power Seats ( drivers )
    LIFT
    10” spring lift (no blocks)
    3” Body Lift
    NEW CUSTOM DASH
    Auto meter Ultra lite Gauges
    NEW 5” Electro speedo
    NEW Electronic speedo sending unit
    NEW 5” Tach
    NEW 2”Oil press
    NEW 2”Clock
    NEW 2”Head temp
    NEW 2”Oil press
    NEW 2”Fuel Guage
    NEW PRODUCTS JUST INSTALLED LESS THAN 200 MILES
    NEW ORD crossover
    NEW ORD High Steer
    NEW ORD bolt on steering brace
    NEW 2WD WTO steering box ported for Hydro Assist (Bought from ORD)
    NEW power steering pump
    NEW power steering lines
    NEW extended Stainless steel braided brake lines front
    NEW Stainless steel brake lines in rear
    NEW FORD shock towers (not installed yet)
    NEW 16” travel Emulsion race runner shocks ( not installed yet )
    NEW DIY4X Shackle Flip and Switch
    NEW 6” Shackles rear
    NEW Poly Spring Bushings (not installed yet)
    NEW M.O.O. Center Shock mount for rear shocks (not mounted yet)
    NEW ORD rear spring reversal plates and u-bolts
    NEW ORD front spring u-bolts and D-60 studs
    NEW 25 GAL. JAZ fuel cell (the metal incased cell) with sending unit
    NEW Clear filler tube fender kit (fuel Cell)
    NEW Stainless Steel Braided fuel lines
    NEW Holley Fuel Pump
    NEW High Flow water pump
    NEW heater core (not installed yet)
    NEW Bushwacker fender flares front installed (rear set not installed yet)
    RIMS & TIRES
    NEW steel 15x12” 8 lug rims Custom painted
    44” boggers around 1000 street miles on them
    NEW Inovation balancing beads ( no weights on rims to loose, never have to balance again )
    I drive this rig daily on I-15 at freeway speeds and have absoulutly NO shimmy shake and that’s with 44” boggers.
    Extra set of 15” aluminum Mickey Thompson rims
    ENGINE
    350 C.I.D.
    Edlebrock intake
    Edelbrock carb 650 CFM
    Hooker headers
    2 ¾ inch exhaust
    Custom Coffin Mufflers ( I bought this rig from the owner of the company that makes these custom mufflers )
    5” chrome tips inside frame rails
    TRANSMISSION
    700r4 OD rebuilt
    NP208 rebuilt
    (1500 miles on tranny and transfer case)
    NEW Rebuilt Driveshaft ( 200 miles on it )
    REAR AXLE
    Rebuilt 14 Bolt F.F. Rear End
    -Completely rebuilt
    -New Timken bearings from hub to hub
    -New Rotors
    -New wheel studs pressed in
    -New disc brake kit with Caddy calipers and ss braided hose kit (from AzKickin offroad)
    -New Rotors
    -New Yukon 4.88 gearset, professionally installed with new bearings, seals
    -New Detroit locker
    -New Bluetorch Fabworks 1/4" plate diff cover
    -Filled with Redline Shockproof gear oil
    -New ORD Spring Perches
    -New Billet Aluminum Wheel Spacers 1 ½ “ rearend now tracks the same as the front
    -NEW Coversion U-Joint
    The axle has been sandblasted, cleaned and painted with POR15 basecoat and topcoat. Maybe has 200 Miles on it since rebuilt and installed
    FRONT AXLE
    Rebuilt Dana 60 Front axle
    - NEW Bluetorch Diff cover
    - NEW custom Diff Cover Guard (cage)
    - NEW bearings
    - NEW calipers Ground for 15” rims a lot of meat left took the minimum needed to clear rims
    - NEW pads
    - NEW rotors
    - NEW spindles
    - NEW kingpins
    - NEW kingpin bushings/springs and lower bearings
    - NEW ORD's hi-steer arms on it ($300)
    - Stock 30 spline outers and the stock inners
    - Warn standard lockouts are on it which is what I bought it with
    the D60 has been sandblasted and POR15'd with top coat. Maybe has 200 Miles on it since rebuilt and installed. (while on deployment the battery fell over and leaked on the axle while in storage so the POR15 bubbled up....I will clean it up best I can for now and paint it black.)
    Also, the axle shafts are not in it at the moment, the axle tubes and backs of the spindles are capped to keep dirt out.
    I was planning to install the axle and drive it to a shop to have the front gears done, but after I installed it I was sent to Iraq and haven’t gotten new gears and locker put in it yet. All it needs is gears, locker and then the axles put back in.
    I am sure I am missing some things but that is the meat and patatoes of the Blazer.
    $5000.00
    I am open for offers so do not be shy try me if it is a smokin deal and I am in the right mood I might just give it away.........:rolleyes: maybe not give it away but I am flexable.
    Call me
    760-224-4299
    or email or PM me.
    usmcgame@yahoo.com
    thanks for looking
    Jared
  2. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I remember your old thread on selling it and it is one beautiful machine. Hope you get everything out of it, don't settle for a penny less!
    -Avery
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    This is another great example of a great, rust-free truck to which someone else has already done all the major big mods, and would be a steal for someone that can live with just doing a little assembly work on that D60. You couldn't build it for anything near the selling price, and a '73 is smog-exempt in California. Buy this thing!
  4. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    lol, were you talking to me? I wish but it's a little out of my price range, plus I'm working with vrigilh on getting his Diesel titled Jimmy with the 5.7 Vortec and such. This is a great looking Blazer and I hope somebody on here picks it up so it doesn't leave the site!
    -Avery
  5. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    No, that was for everybody that stopped by the thread, especially those guys that have almost totally stock rigs that they seem to want to modify heavily. They'd save thousands of dollars by buying something like this truck, since most all of the usual big mods have already been completed. If it wasn't half a country away, I might even take a look at it myself as an upgrade to my rusty '85.
  6. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Oh, ok. That's so true though, this would save a ton of $$$ for somebody that wants a trail/mud worthy rig.
    -Avery
  7. seattle73k5
    May 6, 2005
    210
  8. seattle73k5
    May 6, 2005
    210
  9. Full Tilt
    Full Tilt Registered Member
    Jul 10, 2006
    16
    hanover park illinois
    just wondering what shipping would cost to 60133?
  10. seattle73k5
    May 6, 2005
    210
    I have no idea, contact a shipping company and ask my zip code is 92054.:confused:
    Wish I could be more help.
  11. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I PM'd ya' about an offer, check it out. Man I love the look of this rig. Plus ya' can't beat that drivetrain either for a dd/mudder/sander.
    Oh and for the guy with shipping expect to spend about $800-$1000 on it. Probably on the one grand side especially because of the size, they will hit ya' big for that, trust me I've checked. ;)
    -Avery
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Link to the eBay auction?
  13. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
  14. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    wow that really turned out nicely...i remember when it was on 10 bolts, and people were givin u crap bout it bein "too big"
    i love the rims, how did you do that? did you do it yourself, or have someone paint them?
  15. seattle73k5
    May 6, 2005
    210
    Thanks MuddyBuddy for the compliments I think it turned out good as well it does need a bath and some dusting done inside from sitting while I was gone. Or maybe a run in some mud to make it look just right for the next owner:haha:
    But thanks Yeah I remember the 10bolts they looked like twigs under this beast with the 44's. the running gear in it now makes a huge difference.
    It is just waiting for someone to buy it so it can be driven :D
  16. seattle73k5
    May 6, 2005
    210
    Oh yeah the rims I did myself painted them a mat black and then used a big peice of rolled construction paper stuffed the edge of the paper in the seem between the two sections of the rim and sprayed the green turned out freakin awsome but that's just my opinion :D
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea i love that look, i think i might do that with mine (except black and red, since my truck is two tone black and red)
  18. seattle73k5
    May 6, 2005
    210
    would look great on your rig! you need alittle mudd on it too brings out the red:D
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i took it wheelin for the first time after the axle swap and new steering...wow it was sweet. i got stuck tho...shoulda bought boggers haha. but this truck sees the street way to much and boggers suck gas milage like its their job. maybe ill get a second set of tires hehe
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    interesting. i always thought '73-75 Blazers were full convertables and '76+ were half tops like this one. :confused:
