Sold
Discussion in 'Suspension | Axle' started by DPI, Jul 25, 2006.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    SOLD!
    The front is locked with a new Detroit Locker with zero miles and a new pinion brake setup. See detailed pics of the axle here.
    The front includes a heavy duty double ended hydraulic steering cylinder, tie rods, and heim joints, that are mounted and ready to go. See detailed pics of the cylinder here.
    The front axle is the better U-joint type shafts and has been rebuilt with new seals and the USA6x6 rubber boots.
    The rear is also included. It has been Lincoln Locked and also inlcudes the same pinion brake setup as the front axle.
  2. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    hey, if you dont mind could check shipping to 89423. i also have access to a shipping dock and a fork lift if that helps out with shipping costs at all. Thanks.
    Cory
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yellow Truck Freight would be $200.
    dpi
  4. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    shipping to 78586
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Freight is $125 via Saia.
    By the way - I am in Northeastern Oklahoma - Picking these up is welcome!
  6. RGV72BLAZER
    Jan 23, 2006
    2,425
    just wondering if these could be run on a Gen1...or how much modification would be needed...thanks...& i'm guessing no rear steer?
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Are the spring perches different widths on the Gen 1?
    Nope, no rear steer.
  8. RGV72BLAZER
    Jan 23, 2006
    2,425
    front spring perches are the same on all GMs...rear is about 2 or 3 inches narrower. the front has everything needed to do the steering or what else would be needed?
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    These are sold pending receipt of payment.
    dpi
