Sold
Discussion in 'Engine | Tranny | T-case' started by 87GMC, Oct 30, 2006.
  1. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    I have a complete, as in I just drove the truck Saturday, hydro 465/208 setup from my 87 GMC shortbed. It is still in the truck and when I pull it you will get everything needed to swap it over. Includes pedals, master cylinder, reservoir , fluid line, slave cylinder, hydro bellhousing, fork, flywheel, clutch, throwout bearing, 32 spline 465, adapter, 32 spline 208, both shifters w/ boots+covers, crossmember, t/case skidplate (not OEM), both driveshafts, and all the bolts.
    The 465 was rebuilt less than 250 miles ago. The third gear jumpout fix from anaheim gear was installed.
    http://www.4wheeloffroad.com/brandpages/chevy/131_0208_sm465_transmission_rebuild/specs.html
    The driveshafts will fit a 10b, d44, or d60 front and a 10b/14b rear. I will include a conversion u joint if you need to match to a 12b rear.
    Everything is in great shape except the rubber line from the reservior to the master could use replaced and the front driveshaft slipyoke is worn.
    I'd like to set as a complete kit for $750 unless I find buyers for everything.
    I'm willing to make a roadtrip within 250 miles of KC for free if someone buys the complete kit.
  2. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    I'd sell for $650 if you come and pick it all up.
  3. badger red
    badger red 1/2 ton status
    Jul 30, 2004
    208
    south central KS
    Are you willing to separate? I'd be interested in pedals, master cylinder, reservoir , fluid line, slave cylinder, hydro bellhousing--shipping to Maple City KS 67102?
    Sent you a PM also.
    Jeff
  4. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    PM replied to
  5. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    I need the whole shebang, I might even have a place in KC for it.
