Solid axle NP241 and IFS NP241-what's the difference?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AJMBLAZER, Mar 25, 2001.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    Solid axle NP241 and IFS NP241-what\'s the difference?
    Okay, I definately want to put a solid axle up front instead of the no articulation IFS I have. Thing is, I want to change my transfer case and put in a GM front axle. I can get all the 10 bolts and GM D44's I want, but try finding a Ford solid front D44 and I'm in for a couple of months of fun, and forget about a Ford D60.
    I like my NP241, plenty strong and has nice, low gearing for a nice slow crawl in 1st gear at 4lo. My Blazer has a 4L60 (renamed TH700R4), and I doubt there is any difference between the one in it, and the one in a 89-91 Blazer or Suburban. So if I was to lay my hands on a NP241 from a 89-91 Blazer, would it bolt right up?
    The front axle mountings and all that are going to be handled, I'm just starting a shopping list.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Flowmaster, K&N, 2.5" Rancho, 285/75R16 on 16x8 Baja's[​IMG]
  2. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    Re: Solid axle NP241 and IFS NP241-what\'s the difference?
    If you decide to keep the case you have now you can also use an axle from a full size Jeep, like a Wagoneer or J10. Dana 44 with the pinion on the same side as your IFS NV241. It is easer to adapt because it doesn't have all the odd cast in parts for the radius arms. There are four of them in the junkyard by my house. They seem to be easier to find than the Ford solid axles. Maybe because there is less of a demand.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  3. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    I want to keep it all GM personally, but I am building it with the intentions of possibly one day taking it to New Zealand. Chevy and GMC trucks are semi-common down there and you can also get parts for them semi-easily without having to pay to much money. Everyone else's trucks actually aren't all that common down there. Actually, there are some Fords, and not very many of the Dodges or Jeeps. Would suck if I busted something and needed a part, but the only parts I could find were back in America.
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Yes, the transfer cases are the same except for the output on the IFS being on the drivers side, and opposite for the solid axle model. Just be sure that if you have a 700R4 tranny that you get a 27 spline input versioned 241, as the 400 tranny 241 version's input has 32 splines. The bolt patterns, however, are the same. Good luck.
    ken
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You might run into a difference in the speedo parts, electronic vs. mechanical. I would think that the tailhousing and associated parts would swap from one case to the other though.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
