solid axle questions
Discussion in '1992-Present Chevy & GMC models' started by k5 krawler 50, Mar 26, 2005.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I've recently been looking into buying a 1990-95' silverado and have a couple questions about doing a solid axle swap to one. First, I have a chevy dana 60 front axle that i would like to use for the swap. I know that the 88'-present have drivers side drop gear housings. I was wondering if there was a transfercase that i could use where i wouldn't have to cut a bigger hole in the cab floor for the shifter? I really dont want to butcher the tranny belly( i guess thats what its called). I've seen some chevys around town with pass. side drop axles and was wondering what they did for transfercases. Or do you think it be better to just buy a 2wd model and do solid axle conversion, and just cut one hole for the t-case shifter? But the thing with this is i dont know of a company that makes a 2wd solid axle kit. Also when doing a solid axle swap, do they use a 73'-87' front leaf spring or a different length? Thanks for your help.
    Cory
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    don't know of anyone that sells a 2wd swap kit. Something about the front crossmember hanging down low. As for the shifter hole, don't know of a single passenger side drop that doesn't also have passenger side shifters. You are pretty well stuck on that one. You could just cut the hole, mount a shifter and weld a patch over the old hole to seal it back up. New carpet out of a 2wd(no shifter hole) and bam you'll never know the difference.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You could always sell the chevy 60 for a ford HP 60, thats prolly be the easiest.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I second the idea of swapping to a HP Ford D60, it really helps with your front driveshaft angle. The kits use the front springs for the 73-87(91) trucks. You will get about 2" or 3" lift from the brackets themselves - example: If you use a sas swap kit and 4" lift springs, you will get 7" of lift. It can be done on a 2wd but you will have to make your own brackets and shackles. The engine crossmember hangs down real far on the 2wd trucks but you can cut the bottom of it off and weld a plate on it. The spring cups for the coil springs are part of the frame and you will notice them after the swap, there is no good way to remove them.
  5. tlarsw
    tlarsw 1/2 ton status
    Jan 12, 2001
    270
    Cameron, NC
    I'm doing that exact thing right now. I have a 96 2WD 2500 that I'm converting. I'm getting a bare 4WD frame from a local junk yard for $500 and swapping everything over. I'm using a GM D60 and running a TH400 version NP205 behind a 4L80e. You can have the front indexing machined down on the stock th400/205 adapter plate (long input shaft) and bolt it right up behind the 4L80e.
    Tim
  6. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    al rite cool, thanks for all the help, i will check into the costs of ford hp 60s, and if worse comes to worse then i will just cut the hole. Thanks for the help.
    Cory
  7. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    ORU kit gives you 2" additonal lift. I wouldnt use their kit though, its easy to make your own, espically if your ding it on a 2wd.
  8. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    does any one make solid axle swaps besides oru?
  9. divorced
    Jul 20, 2004
    5,115
  10. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    They do, and they have for a while, but they suck at updating their site. I think it was around $1600 for brackets and steering, but I can't remember if it includes springs or not.
  11. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    ya i like the look of there stuff better than off road unlimited crap. and yes thay need a update bad!!
  12. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    does anybody know how to get a hold of fabritech?
    Kevin
  13. thezentree
    Sep 19, 2003
    7,198
    NC
    setstr8.com
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    ............4 link........
  15. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Thanks for the info on fabritech. Has anyone fab up their own brackets? If any one has pix of them i would like to see them please. Thanks for the help.
  16. divorced
    Jul 20, 2004
    5,115
  17. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    cool, thanks for that. Some good measurements on there. Thanks a lot.
    Cory
  18. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    there is no phone number on fabrtech's website!!!!
    Kevin
  19. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Any one got any other good measurements. Also drawings or pictures of the brackets. Thanks for the help.
    Cory
  20. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The brackets in the first link has a bit more then 2" additional lift. He did it good by bracng the hangers together. When you do it, depending how big you go, it would be a good idea to make the front hangers longer then the rear shackles, for better pinion angle.
    The one in the second link has the ORU kit. Thoese guys and their panhard bars.
