Solid front axle vs. IFS
Discussion in 'The Garage' started by rotorjockey, Jan 7, 2006.
  1. rotorjockey
    rotorjockey Registered Member
    Feb 28, 2004
    30
    Phoenix, AZ
    Other than cost, which Im sure it will be expensive, please share pros and cons of converting an IFS to solid axle if you have done this.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    You can do a SAS cheaper than an IFS lift, but depends on what axle you use. If you go with a Dana 44, or happen to find a 60 cheap, all the other stuff can be found in a junkyard. The most expensive thing on my truck is the ORU kit. If you know how to weld you can make your own set. I found a set of 4" springs in a j/y, got the pitman arm off a 1/2 Ford, GM 3 peice tierod shortened for a draglink, and $60 for steel braided lines and fittings. Had to buy the crossover arm, which is something that you have to do on these trucks. You could mount the box on the outside of the frame, that is a PITA. I'm going to do another SAS in my 97, gonna make my own brackets, and right now I have about $500-600 into it. That included buying a HP60 too. I never owned a lifted IFS, so I can't compare. But I know some of the places that I've been with my truck, and IFS wouldn't have survived. From all the readings about lifted IFS's, the stuff wears out, and have to rebuild it every other year. And that's street driving, not taking it offroad. Go SAS, get the peices a couple at a time, then go for it. You won't be dissapointed. You will get props for a SAS over IFS lift, too!! Forget to mention, if you want to go bigger, just get a set of springs, just like the older style. It flexs 10 times better, ride isn't that much different, (still tweaking mine), the front end doesn't wear out, can unlock the hubs, less wear and maybe a little better MPG. Looks better than all those brackets and crap. And anybody can put an IFS lift together.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    look under the new sheetmetal section of the forum. all you need is misc stock mounts, a solid axle and a set of 52" springs. 4" lift and for about 100 (not including axle)
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I'll agree with you, except for this part. A lifted IFS will ride/handle a lot better on the street than a solid axle truck.
  5. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I say skip the sas, keep that truck stock for a dialy driver and go find a beat up solid axle chevy. That way you can wheel the piss out of it and not be worried about driving it to work on Monday!
  6. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i agree i dont like ifs
    you dont gain any ground clearance with a lift, but you also have stuff that is not as strong. i say dont bother and find a solid axle fullsize and wheel it instead of doing a conversion
    LUKE
  7. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    How does an IFS lift not gain any clearance? You gain the same clearance with an IFS lift that you would with a solid axle lift of the same inches.
  8. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    the tires are what creates the ground clearance.
    you lift it to put bigger tires on it.
    unless you are just cranking up the torsion bars and increasing the angle of the lower control arms, you are gaining no lift. *edit* should read "clearance"
    a six inch ifs kit and a six inch solid axle kit gets you the same amount of gain in clearance. which is zero.
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    actually you gain breakover angle and approach and departure angle with a lift. So clearance is gained. but less is gained with an IFS lift because of the torsion bar drop brackets that hang below the frame.
