Solid motor mounts?
Discussion in 'The Garage' started by PsychoticDeadGuy, Nov 23, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Are there any benefits or drawbacks of running some solid mounts? and put some solid ones on my tranny too? a friend of mine has some small block chevy mounts that i could get from him but im not sure for off road use if they would be a smart choice? i know people run the poly ones and they dont flex much at all but what about solid?
  2. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    I thought it would be an advantage because you wouldn't have to change your motor mounts but you will feel alot more vibration through the frame... same goes for the tranny mounts... i've found the best of both worlds is the motor mounts that use polyeurethane. It won't wear out nearly as quick as rubber but will still obsourb vibrations.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    IMO without some give in the mounts, you will break more stuff. I suggest going with poly or other heavy duty mounts. The vibrations from solid mounts drive me crazy, plus they make all the rattles in the truck much worse.
  5. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    the energy suspension ones work good and still give a bit. but nothing like stock junk. all solid will break stuff fast. the frames flex way to much for use to be running solids.
  6. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    I had solid motor mounts on my Datsun with the 350, and after less than a dozen runs, the engine developed a crack in the block, next to the motor mount.
    Eddie
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    If you do go solid, make sure it is all solid, tranny, tcase everything. Otherwise you will break the bellhouse or tcase adaptor really fast
