Solid Motor Mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bherring, Apr 25, 2002.
  1. bherring
    bherring Registered Member
    Nov 2, 2000
    55
    VA,USA
    Anyone ever made/bought solid motor mounts? I want minimum drivetrain movement but I'm wondering about vibrations. The whole thing is tube body welded/bolted directly to k5 frame. (TRAIL ONLY)
    -Beck.
  2. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    In Offroad racing we use solid motor mounts. We use solid front motor mounts and an engine plate, 1/2 inch aluminum, between the engine and transmission. This requires a very rigid chassis. If I were you I would use a urethane bushing motor mount like the ones AutoFab http://www.autofab.com/chevy.htm in San Diego sells, because of some frame flex.
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    If you buy new mounts, buy them from someone who supports CK5! /forums/images/icons/smile.gif ORD has the same kind of product for $155:
    http://offroaddesign.com/catalog/motormounts.htm
    Help support this page, and buy thru OffRoad Design!
    Just my .02! /forums/images/icons/smile.gif
    -Dan
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    But on the subject of SOLID MOUNTS, /forums/images/icons/tongue.gif I wouldn't want them in my truck, because last set I installed in a race car of mine used to shake the fillings outta my teeth! /forums/images/icons/crazy.gif /forums/images/icons/laugh.gif Granted, there was a 550HP 383 SBC under the hood!
  5. buuugggy
    buuugggy Newbie
    Apr 24, 2002
    Heres what were working with here.....yea..... <a target="_blank" href=http://a3.cpimg.com/image/AB/60/9613483-a6ea-02000180-.jpg>http://a3.cpimg.com/image/AB/60/9613483-a6ea-02000180-.jpg</a>
  6. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Hey that buggy looks cool...! I too am building a buggy. I call it the FunBuggy. check it out on my webshots albums.
    <a target="_blank" href=http://community.webshots.com/user/marv_springer>http://community.webshots.com/user/marv_springer</a>
    Back to the subject line... I ran solid mounts on a Jeep that I had. It was a "sand only" machine and typically saw high rpm and WOT. I loved the solid mounts, and swore that it helped me get up the hill faster. But... I'm using Urethane spring bushing mounts for the FunBuggy. For crawling and low rpm stuff I can't imagine that the solid connection would help, and the bushings will eat up some of the vibration.
    Marv
  7. dyeager535
    26,977
    The last write up I had seen on solid mounts (perhaps in some "build a small block chevy" books) mentioned that the problem with them is that they distort the block moreso than stiffer, yet still flexible, poly mounts. I was always afraid you might break the block, but apparently the block flexes ok, its just that it affects those cylinders near the mounts. FWIW.
  8. dyeager535
    26,977
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Solid mounts + flexy truck = broken trans case
