solid motor mounts
Discussion in 'The Garage' started by milspecjimmy, Feb 15, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    any one use em? and what part # did you use for a later style clam shell mount?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Wouldn't go there unless it's short use only rig. Like 100 yards or 1/4 mi. at a time. Will shake like a dawg sh*ttin peach seeds.
    Might talk to Scott @ Rockstomper about making some GM apps similar to his yoter engine mounts if he doesn't already make them.
  3. FULLSIZE
    FULLSIZE Registered Member
    Aug 8, 2002
    76
    dont use them unless your plan to run all solid mounts(tranny/t-case,etc) or you'll crack the trans case or adapter. i would find some kind of fail-safe type mount or through bolt the current ones. /forums/images/graemlins/usaflag.gif
  4. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    i am open to suggestions, and am tossing in another motor in the next few days
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    R u just looking for something stronger than the stoke setup? When I put my BBC in, I am using the Energy Poly Inserst...You could always use the mounts that ORD sells...they are pretty beefy..
    Chris
