solid tie-rod bar???
Discussion in 'The Garage' started by 85mudblazin, Nov 8, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    could you make your tie-rod out of say 1.5" solid bar and then just drill and tap the ends?? I think it would be super strong compared to DOM tube.
    -Chris
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    If I remember correctly, tubing should be stronger than a solid bar. The reason is the tubing has 4 walls (2x inner, 2x outer) to resist flex/damage, whereas solid bar only has 2.
    Of course, adequate wall thickness plays into this as well.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    3/16" DOM is quite a bit more bend-resistant than solid rod. It usually springs back a whole lot better than solid rod also.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Nope, DOM is MUCH stronger than solid round stock.
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Mine are from WTO and they are solid. Real Beefy
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thats cool I just figured heavier is better /forums/images/graemlins/thumb.gif
    So what is the strongest tie-rod on the market??
  7. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Pretty sure they'll go through the trunk of a cavalier from the inside out too...
    I have the West TX OffRoad solid Alum. 7075 1.5" diameter tie rod on mine.
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The steel shop I go to has 1.5" .375 wall DOM in stock. Slide some 1.75" .120 wall tube over it and you are in axle territory.
