Solution for drive line angle?
Discussion in 'The Garage' started by grizzlyoffroad, Apr 13, 2006.
  1. grizzlyoffroad
    grizzlyoffroad 1/2 ton status
    Mar 31, 2006
    100
    Soldotna, Alaska
    OK guys, what are your thoughts on solving the high front drive shaft angle problem. I am putting a 10" suspension lift on my blazer and wondering what the best solution to the drive line angle problem is....Should I lower the transfer case, reclock the transfer case, cut and rotate the front diff...or combo of some/all? Also, what new drive line do you suggest? Thanks
  2. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    I'm guessing you have an NP205. I'm not sure if you can clock the older ones with the figure 8 mounting pattern. Lowering the transfer case will help the rear shaft angle and hurt the front. I wouldn't do it. Look at using a 1350 CV on the front and rear. You'll also need to cut off your rear spring perches rotate and weld on new ones. You will need to cut and rotate the front differential to get the driveshaft lined up and set the caster right.
  3. grizzlyoffroad
    Mar 31, 2006
    100
    Soldotna, Alaska
    How can lowering the t-case hurt the front drive shaft angle? If it is getting one closer to the stock angle, then it must be getting the other???? right? And yes, I have the 205.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    First you have to grind the yokes on the CV to get that kind of angle out of them. Second you have to cut and turn your knuckles, the same time you are doing this you either have to run shims in the front to get the pinion in line with the driveshaft or cut off the perch and reweld it and then take the axle to a machine shop and have the cast in perch put at the same angle and redrill the holes. Problem solved. I know its alot of work its what I am having to go through too. You can run the shims in the front until you get the money to have a machine shop do it the other way. I am running about 10" of lift and the only problem I have with my front shaft is the slip yoke is too short. I ran it this way with a full time 203 so the driveshaft didn't vibrate very much
  5. Dallin
    Feb 12, 2003
    135
    You're not just lowerin the t-case you're tipping it. This increases the front shaft angle. If you lowered the engine mounts at the same time you wouldn't get any tipping.
  6. grizzlyoffroad
    Mar 31, 2006
    100
    Soldotna, Alaska
    Ohhhhh:wink1: , I'm picken up what you're laying down....thanks for the clarification.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    I would say the best way would be to get a high-pinion front axle. After that, T-case clocking is a good approach. Less suspension lift is a good choice if you can do it (you could always use a body lift as well).
    After that if you're talking about dealing with the angles, a high $$ driveshaft may be the only choice.
  8. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I have a severe angle that I had to correct with a 2-piece carrier bearing drive line...................But a high pinion axle would solve your definetly solve your problem.
  9. grizzlyoffroad
    Mar 31, 2006
    100
    Soldotna, Alaska
    TTT....any other ideas or comments???
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    for the front????
  11. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    Hi pinion axle... add a doubler (or divorced 205 if you wanna be cheap!)... move your front axle forward. Less lift would help a lot...
    j
  12. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Yes ... I beat the piss out of it in Moab and it works great.
