sombody with 14ff disk and caddie calipers help me!!
Discussion in 'The Garage' started by ducttape114, Sep 19, 2003.
  1. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i cannot get the loaded calipers over the rotor. i dont know if i got the wrong rotors or pads or what. but they are not gona fit. i tried compressing the piston with a C clamp but i think its all the way open already. im running: caddie calipers, caddie pads, 96 3/4 chevy front rototrs.
  2. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    The problem is the rotors, you should have front rotors from a 71-78 3/4 ton....napa part number 85677 IIRC.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Hey Tape, measure the width of your rotor and post it up. Also, if you get the caddy calipers from anything but a 76-78 el dorado then they wont fit either.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you probably got the seville calipers pistons
    seville
    el dorado
    see my pics
    ARQ.
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    yer right the older ones are too thick 73's work fine
  6. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I don't know if you are aware of this, but the El Dorado Calipers do not operate like most typical disk brake systems. In addition to the hydraulic pressure of the brake fluid that maintains brake pad contact with the rotor, there is also spring mechanism behind/inside the piston. Unfortunately, this means you can not fully open the calipers by pressing them with a c-clamp as we are all accustomed to doing. So there is a possibility you do not have your calipers open fully and thus they won't slide over your rotors.
    Look on your caliper piston, there should be two samll notches ~180* apart from one another. These notches are their to accept a specialty tool that adjust your calipers. I have some detailed directions on how to adjust the calipers with a PN listed for the specialty tool, but unfortunately they are at home. If you don't find what you need by this weekend, send me a PM and I'll scan it into my computer and send them to you. In the meantime, I'd try searching out some caddy web-sites for this information.
    Something else to note, once you put these calipers on you must set the parking brake everytime you park your truck. This allows the spring mechanism to adjust the caliper to maintain proper contact with the rotor as the brake pads are worn dowm.
    Good luck,
    Lance
  7. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    the rotor is between 1" or 1 and 1/32". hard to tell with a tape measuse. i do have el dorado calipers. i bought them from a person on this board and he said they were 76-78. how thick are your guys pads? these ones look to be about 3/8 to 1/2. if they were a little thiner i bet i could fit them.
  8. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Tape, your rotors should be no more than 1 3/8" thick. I've used pads by several different makers and not had any problems with them fitting but have hear of several other people running into what you are... all of them turned out to have 76-78 Seville calipers as Arq has pointed out. If you pull the bolt off the e-brake lever, you can bring the piston back in all the way by spinning the ebrake bolt. While I don't recall having to do it myself when I last did mine, something somewhere said to be carefull no to engage the e-brake with it off the rotor or it will force the piston out of the caliper.
  9. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    ok i will try that.
    BTW, my rotors are 1 1/4" or 1 5/16". i guess i forgot how to use a tape measure. i need to go back to sleep.
    thanks everybody
  10. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    cool, got them both on there. the passenger side still feels pretty tight though, so i guess im gonna have to do that over again. oh well, thanks everybody!!!!
  11. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Sweet~ sounds like you've got your nose to the grindstone getting ready for the first of the month!
