Some Bad Luck (right off the bat)
Discussion in 'The Garage' started by DurangoK5, Jan 3, 2005.
  1. DurangoK5
    DurangoK5 Newbie
    Dec 31, 2004
    Durango, CO
    My little brother just purchased a 90K5. It's lifted, I think like 3 inches. He was driving down the road when a loud noise started in from the rear end.
    And now we have a $2200 bill from the auto shop. Please let me know if these prices sound right or if we're gettin screwed.
    1) Lengthen Drive Shaft - $400
    2) New Ring and Pinions (due to the wobling from short rear drive shaft) $370
    3) New LSD $575
    4) New Carrier Bearings $47
    5) New Rear Left Axle $255
    6) Labor $450
    I didn't do the pre-purchase inspection, or some of this might have been caught, but basically the drive shaft was too short causing a wobling and eventually some type of breakage. I wouldn't be surprised if the left axle was already broken however... And since it had limited slip the damn thing would roll at least... right?
    Any help is greatly appreciated.
    Alan Cantor :mad: :confused:
    :cool1: I still love K5's
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Holy hell, i hope they lubed you up first.....
    $225 for an axle shaft? hell you could have bought a whole rear end for that alone. $525 for a LSD diff, could have bought a better locker unit for like $300
    The short shaft thing to me sounds like a BS reason, there are plenty of lifted Blazers that don't have any issues except some vibration due to the higher angles of the u-joints,,,you are seriously being taken for a ride on this dude.
    Could have also bought a CV shaft for alot less than what they are trying to charge you for lengthening yours.
    $370 is WAAAY too much for a R&P if it's a 10 bolt unit anyways.
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I don't see how a short shaft can cause a wobble?
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Dude you can buy two working K5s for $2200. Forget the rear go to the junkyard and get a 14ff $150, detroit $400 and a driveshaft or have yours reworked $250. Hell you can get a HAD shaft for around $450. Two eight lug rims $100. All this a lot cheaper and a lot stronger for half the money. Or someone on here close to you would prob give you a rear 10bolt axle.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Driveshaft BRAND NEW would be 400.00 or so give or take ,
    not rebuilt or lengthened .
    Internal parts you'd have to ask Tim for a quote .
    225 for an axlshaft ..... ouch . A new aftermarket one starts at 110.00 and up
    Sorry for your luck man . Some of that could of been found here on CK5 , Tim , High Angle , and the parst wanted forums :k5: :k5:
  6. dyeager535
    26,978
    If you ask me, the only prices on there that look somewhat reasonable are the carrier bearing prices, and MAYBE the labor!
    Someone just posted about driveshaft lengthening costing $150 or so IIRC, R&P are probably $150-200 from Summit, Jegs, etc., that LSD better be a GM gov-lock or piece (based solely on the fact that is a factory replacement price IMO), and last I checked on Moser prices, 8.5" axleshafts are about $125 or so, for a basic piece.
    Even if the truck did move with a broken axle, which I doubt is possible, unless this happened 20 feet from the place of purchase, it would have been noticed immediately. It may have needed a new axle due to the bearing chewing it up (even though there are bearings made to repair this problem) or the c-clip end broke off, but I'd want to see it.
    I'm not in the business of repairing vehicles for a fee, but those prices are why I fix my own, thats for sure. So honestly, I doubt anyone but a shop worker who works close to you (cost of living differences can be huge) is qualified to say whether you got taken or not. But the parts you can get yourself, I don't see how the price difference is justified. Maybe thats just me.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    because the splines wouldnt be fully engaged causing it to wabble, my driveshaft is to short but I dont get a wabble it just leaks a little bit of fluid.
    At any rate those prices are really high, you wont want that new limited slip, they break to easy in 10b's, so just install a open carrier. all that other stuff is way to high.
    In my opinion I would just go to a junkyard and get another 10b with the same gears, as long as it is stock they shouldnt be to hard to find, I bet you could get one for $50, and then you are just left with lengthining the shaft which will prolly cost around $100.
    So you are in it $150 VS. $2200 :xmas:
  8. dyeager535
    26,978
    From what I've seen, you let a 208/241 shaft slip around on the output shaft of the t-case, the case itself lets go long before the rear end will. (output shaft housing cracks)
    I can see a loose yoke on the axle though, thats common, and will destroy things very effectively.
  9. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,001
    595
    Pueblo, CO
    Somebody's getting shafted...
    Dude, I think that shop has $$$$ in thier eyes. Worst case senairo on being screwed, all it might be is a fried u-joint and they are taking you to the bank on the rest of it. Take the truck out of the shop right now. Just looking at www.car-part.com a complete axle in boneyards in Colorado has prices for a complete axle between $700-950 and axle shafts for $90-120
    I don't think a 3" lift would cause so much driveline angle that it would wipe out the pinon bearing (and cause the rest of the damage listed). At least not before wasting the rear ujoint first. Even then I'd think that the u-joint would break before the pinion bearings would be ruined.
    As for the axle shaft, someone else noted there is something you can use to keep your axle. They are called axle saver bearings. They move the roller bearings out of the groove cut by the old bearings and have the seal as part of the unit as an "all in one" fix. I got a pair in the 10 bolt in my Nova. I think they were like $35 a side, but I didn't have to buy axles. Yes new axles are best but on a budget its the way to go.
    Heck I'd give you my 12bolt if you had a 14FF to trade. I want to upgrade!
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Obviously, if you haven't already spent the money - go somewhere else
  11. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    :confused: :confused: :confused: dood!!!!!! all i got to say is wtf? yep those are insane prices. i had an 81 lifted k5. and i had 6" lift with 35x14x15 super swampers with a stock driveshaft!!!!! and mine had some vibrations but never broke till i semi purposefully broke it. i was dragracing a friend in his 79 stock k5. yeah i dumped the clutch on a 4 speed in 1st gear with a healthy 350 and 35" tall 14" wide softer rubber tires at a stop light :grin: fully knowing that i had a stock driveshaft in it :haha: and then, i broke both u joints. even snapped 3 sides to one off :haha: but my truck had a bigger lift with a big tire on it so i dont see how just a 3" lift would make that big a diff. and you didnt specify if it was body or suspension. body wouldnt change the driveline at all as where the suspension would. and all i did to correct my driveshaft issue after breaking was put the driveshaft from a 79 k5 in it. it had a slip collar (whatever you call them things) on it so it werked better. :grin:
  12. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I agree with everyone... they are trying to take advantage of you bad.
    Real bad.
  13. woods
    woods Registered Member
    Feb 18, 2003
    73
    I just had my drive shaft lengthened and a new yoke installed and new u joints, and it came out to 306 or so. So yeah I think they are trying to screw you.
  14. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Holy shnikeys!!!
    Dude those prices are insane. At this point I'd tell them to keep their axle and drive shaft, tow the K5 home with only the front and run down to the junk yard and pic up another axle for $150 or so. Hell I just gave away a complete set of axles for free about 6months ago. It happens on here all the time, free 1/2 tons that is. Last drive shaft I had lenghtened cost me $40.
  15. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    It sounds to me as if the work has already been done. Otherwise it should have read "We have a $2200 estimate for repairs".
    That is the entire reason I do not ever take my vehicles anywhere to get repaired. It costs me less to educate myself and invest in a few special tools so I can do all my own repairs. Plus, I know exactly who to cuss out if the repairs aren't up to snuff.
    Rene
  16. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    couldnt have said it better meself. good point Rene!!! im 300% in agreence (sp) learn how to do things yourself so its done right and if not you get to learn more from it. makes us all better. :waytogo:
  17. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Durango.... so what happened?
