Some GM D60 Qestions...
Discussion in 'The Garage' started by JK5, Jun 13, 2004.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I plan-on putting 5.13's in my GM D60..
    I have 4.10's at this time..
    Since I have a ARB...
    I like to find a set of thick gears...
    Who has them??
    Has anyone used the spacer to adapt 5.13's to your 4.10 carrier???
    Thanks..
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    As far as I know you will have to run a spacer. There are no thick gears available for a standard rotation D60. If it is set up properly it will be fine with a spacer in the front axle.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no one sells thick gears for D60, just have to use the spacer. I have a spacer, not using it though, been told not to, no idea on it really.
  4. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    So where does this leave us? /forums/images/graemlins/dunno.gif
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    New carrier or the spacer. Most people will say not to run them and I would agree for a rear axle but in the front it should be fine. I know a couple of guys with pulling trucks running spacers in the front and have had no problems with them.
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I guess this is what I'm looking for...
    Someone that is using a spacer...that hasn't had a problem.. /forums/images/graemlins/peace.gif
  7. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    I have the spacer on my truck with a 4.10 version Detroit Locker. I have 4.56 gears. The spacer was like $30 from Randy's Ring & Pinion. No problems with it and I have been running it for 2 yrs now. Done some preatty hard wheelig with it too. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I could have sworn they made a set of thick gears. On closer look I guess they don't. /forums/images/graemlins/frown.gif
  11. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Add me to the list of spacer users.
    I ran 5.13's on a Trac Lock in a D60 for about 5 years with no problems. /forums/images/graemlins/thumb.gif
  12. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Went through the same deal a couple months ago. I was going to swap in 4:56's but don't want to replace the carrier yet. I was going to get a spacer but decided that lower gears in the t case would be more usefull.
  13. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    They make a thick set for the Ford HP D60...
    because ford HP60 only came with a 4.10 carrier..
    But nothing for the standard rototation GM 60...
    You have to use a spacer... /forums/images/graemlins/tongue.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't think I'd really want to use a spacer. This throws me a curveball now.....I wanted to go to 5.13s and I run the lock right. That means I have to either buy a detroit or find a 4.56 open carrier. /forums/images/graemlins/dunno.gif
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    [/ QUOTE ] /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Aren't you using yours?
  17. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I wouldn't worry about it...
    Maybe check torque on carrier bolts..more often.. /forums/images/graemlins/rolleyes.gif
