Some good disk brake install info.that I found out about.
Discussion in 'The Garage' started by 87GMCJimmy, May 23, 2002.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    A friend took his G/f's 96 chevy 2 wheel drive truck to Just Brakes because something was wrong with them and it was eating pads. Apperently that the last person to work on the brakes (previous owner) had put new calipers on and not installed them correctly. He said when putting new calipers on almost any vechicle it is very common to have to grind the calipers so that it can move freely and not stick. I never heard this before. Most people when they have a sticky caliper just through a new one on and don't really fix the problem. I know I did. The truck now drives better than ever. Maybe if I do this I'll get a longer brake pad life! Hope this was helpful and a plug for Just Brakes, they seem pretty good.
    Later
    Mike
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    siezed caliper guide pins?
  3. Grim-Reaper
    7,385
    Atlanta
    I have never had to grind them but I have had to clean the guides OFTEN to remove mud and dirt from wheeling /forums/images/icons/smile.gif I just redid my fronts that the passenger side was so jammed up one pad was worn out .It was also worn into a wedge shape.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I have never seen chev style wear pads properly
    my 60 is easy on pads
  5. Grim-Reaper
    7,385
    Atlanta
    Yeah that's true but this was beyond the normal uneven wear.
    I am so hacked. the rubber bushings that go in the ears of the calipers where the guide pins ride on were worn out from the mud. The calipers were reasonably new and it excelent shape. I could not find those parts for nothing! I checked with about 3 places (zone, pep and advanced) and could not get them unless I got a rebuilt caliper. Didn't have time to drive halfway accross town to Napa to see if they had them. Just rolled them inside out to buy some time.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you check a Genuine Chevy service manual there's a specified gap at the sides of your calipers. Sometimes you need to take a file to the caliper or mount to remove burrs too.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I did that search once
    ended up spending more then a rebuilt caliper
    was real POd when i bought a set of calipers and all the guide pin bushing were included for less then i paid.
    dealer item$$
