Some help with codes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris87K5, Sep 23, 2002.
  1. Chris87K5
    Chris87K5 1/2 ton status
    Sep 21, 2002
    322
    Pennsyltucky
    Ok, I am getting the following codes from my 87.
    24,43,and 44. Can someone help me to fix these. The main problem I am having is an extremely rough idle and sometimes stalling. /forums/images/icons/confused.gif
  2. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    IS it blowing black smoke like it is running ritch?
    I can find out for you tommorrow when I go to work and look and the code book.
    colin
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Ok, code 24 is Vehicle Speed Sensor Fault
    code 43 is Electronic Sparck Control Bypass or Failure
    code 44 is Lean exhaust mixture indicated.
    Hope that helps, If you have access to a laptop you might want to check out WinAlDl, just do a search for it on google and the site will come up.
  4. Chris87K5
    Sep 21, 2002
    322
    Pennsyltucky
    It doesn't smoke at all.......Actually it runs fine with lots of power when I am on the gas, it just doesn't idle good.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    87 blazer here... do I need a serial cable with a special dongle to use the program on my vaio? Been wanting to try this for awhile! Thanks, Jeremiah
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    http://www.winaldl.webhop.net/
    5.7L TBI - (L05) - (K) - 87,88 TRUCKS
    MW2 uses "Idle Flag" and "High Bat Voltage"
    MWAF1 uses "Clear Flood Flag" TBI data streams
    READ DATA ON PIN "E" OF ALDL CONNECTOR
    .....So what does this mean?
    links
    making a cable
