Some items for your engine needs!
Discussion in 'Vendor Forum' started by cybrfire, Dec 16, 2005.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    couple items here for your engine needs
    First up is a Seal kit meant for sealing engines for long term storage. Bags are fine for short term but will never hold up for very long. Everything in the kit is 10ga. steel except for the lift plate which is 1/4". Not pictured is a plastic plug for the distributor hole.
    SBC, Exhaust port seals, water pump and water neck seal, fuel pump block off and lift plate. Fuel pump block off is heavy enough to use as a permanent block off when switching to an electric fuel pump.
    Kit cost as pictured (unpainted) with the plastic dist. plug is $25.00 plus shipping.
    Kits for other engines will be developed.
    Second item is a Engine balance plate. You'll need one of these if your building a 383 or 406 externally balance but using the small 350 flexplate.
    I'm not an engine builder but Coonie's Racing engines that moved into the shop this past fall has been working with me to get these out so here they are. Made of 13ga. Cold rolled steel.
    $9.00 plus shipping.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You really make some cool stuff.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Thanks! I really like the outcome of the Engine seal kit. There are other kits out there but none (that I know of) that are quite this thorough. I've been stock piling some small blocks for future use and if your like me, moving the lift plate from engine to engine and then putting plastic over the engine or shoving something down the intake seems kinda ridiculous. Hopefully we've priced this low enough that the engine lift plate can just be left on there.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I would say yes... only problem is it wont work with my cummins or 6.2L's :doah:
  5. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Cool item, do you have plans for a BBC seal kit?
    Jimbo
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    cool stuff. I might have to see what Coonies can do for me when I need an engine later in life. I think if I am gonna try TTC-style comps at some point, I'm gonna need an FI'd 454...
    j
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Yep, BBC is one of the highest on the demand list.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I'm sure he can hook you up! He'll be doing both my Caddies.
  9. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    wow what a cool idea!!!'
    i will tell a friend about it might want one:thinking:
  10. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    will an option of having one side rubber lined be an option? seems like metal to metal won't seal perfectly and being rubberlined on one side would allow ease of install over and over. Just an Idea:D
  11. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    This is probably one of the best ideas I've ever seen.
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Meant to be used with a smear of silicone.
  13. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    You could also go to the hardware store and get a sheet of rubber from the plumbing section. Then use Kert's pieces for templates and cut your own gaskets...
  14. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    I may be getting a engine to build here shortly and when I do I'll pick up a set, I spoke to one of my vendors that rubberize for me and they said the charge should be minimal:D
