some pics of my D60 DRW hubs machined to SRW
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Jul 16, 2002.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    thanks for the pics, they're now saved to my hard drive...pic is worth 10,000 words.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    they went the extra step and added a flange
  4. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    Is the added flange a necessity? I'm going to be doing the same thing with some extra hubs I have and want to make sure it's done right.
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Is the flange added to get the correct track width as a SRW D60 hub? Just wondering why it is needed, if it's to correct the track width then it would make sense, otherwise what is it's purpose?
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Looks Great!
    They are a top quality machine shop. I bought my Dual Transfer Case setup from them. Reveiw to follow shortly, stay tuned...
    I called them and in less than a week I had my parts.
    Hey, while on this subject. What is the bolt circle for the 8 lug? And 6 lug? Just curious.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think it is just to add some strength.
    the track width would be real close without it, as I believe the brake rotors are the same part DRW and SRW, so the diffence would be in the thickness of the flange between the 2 styles and they look pretty close.
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    8 on 6.5" I am pretty sure
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those look very well done. /forums/images/icons/cool.gif I like the flange they added, too.
    How much did this job cost, just so we know what to expect. /forums/images/icons/wink.gif
  10. beater74
    May 29, 2001
    1,749
    atlanta
    /forums/images/icons/grin.gif is the flange necessary, no, several other folks here have done this without installing a new wheel ring. But IMLAO it adds strenght and provides a truer and more stable wheel mounting surface.and yes it is the standard eight lug, but them wagoner folks can make then in about any config. you could want. as for the cost it was $250 for the pair plus shipping ($60 round trip) it wasn't the cheepest by far but i feel i got my moneys worth. i checked with several local shop and they said they could do it, if i told them what to do /forums/images/icons/crazy.gif , i didn't feel comfy with this and ending up with a set of worthless hubs that will cost $700 to replace /forums/images/icons/shocked.gif. also if you do go with them and you use the DRW rotors the holes must be reemed out to 43/64 to accept the new studs (dorman part# 283). if you go with wagoner give'm a call and ask for Casey and tell him the cool box guy sent ya (you can see part of the box in the pic).
  11. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Only difference between single wheel and dual wheel rotors is the diameter of the holes for the 8 lug bolt pattern since one bolts to the hub and the other has the studs pressed through the two.
    I had to drill my original rotors to make them work at first.
    Mike
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I didnt know you had the DRW and conversion...
  13. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I really like the added flange. When I did mine, I just had the outer flange removed and trued the face of the inner flange. It seems to be almost too small of a diameter, I am thinking of adding a flange to mine.
