some Q's about 52" swap
Discussion in 'The Garage' started by AllamericanK5, Feb 26, 2006.
  1. AllamericanK5
    AllamericanK5 1/2 ton status
    Feb 2, 2005
    131
    Colorado
    1 Is it very DD
    2 I have about 5.5 to 6 of lift in the rear can i just put stock 52's up front or do i have to get lift springs??
    3 I also im planing on doing cross over will just any 2wd box work with the pitman arm that is on work ?????
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    need lift springs... 52s give ya 4".
    any 2wd box will work... I forget about the pitman arm details tho...been a long time.
    j
  3. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    How DD'able depends on the springs, IMHO, and your driving style. Mine is looser than it was with Rancho 4" no-flex springs :D
    You need not switch the whole box, unless you want to; you can switch just the sector shaft. You will need to change pitman arms at the same time as part of crossover.
    -- A
  4. AllamericanK5
    Feb 2, 2005
    131
    Colorado
    sweet thank you much. I was thinking about doing the drill and tap on the flat top my slef how acuate dose it have to be? or should i just take it to some one to do it for me and if soo do you know any one here in the metro area?
  5. 468k5
    468k5 1/2 ton status
    Jul 28, 2004
    142
    SE Mn.
    so the stock 2wd pitman arm will NOT work?
    If not what do I need?
  6. 468k5
    Jul 28, 2004
    142
    SE Mn.
    bump
  7. AllamericanK5
    Feb 2, 2005
    131
    Colorado
    some one ne one ???
  8. dremu
    Feb 27, 2000
    15,970
    462
    For crossover -- whether or not you're doing 52"'s -- you need something like the Superlift 1104 arm, or a Ford van arm. Both would need to be re-tapered for GM DLE's ...
    http://www.wfoconcepts.com/Steering/Dana44/CrossoverKit.html
    Trevor has a nice setup, for instance; I'm using most of it. (I also did high-steer.)
    He also does the machine work; there are lots of folks, vendors and a few members, here who do it.
    -- A
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    You will notice a lot of body roll on a DD doing 52's. Just going the couple blocks to the gas station I really notice the leaning. It's not unbearable, but you can't drive it like a sports car.
    THe WFO kit is great - Trevor's a great guy to deal with and his parts are top notch... That being said, since I'm moving up to a D60, I have a 10-bolt knuckle w/ steering arm for sale $200obo + the ride.
  10. Bushido
    Bushido Registered Member
    Jan 25, 2006
    38
    Hawaii
    Would running the sway bar with disconnects help with the body roll and still have the flex off-road?Plan to do the swap as well.
  11. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    umm me thinky that with the axle 2 inch further forward sway bar wont work anyway. or with crossover. hmmmm.
  12. Bushido
    Jan 25, 2006
    38
    Hawaii
    Never thought about the x-over hitting.The swaybar I'm sure wouldn't be hard to fab some mounts for.Might have to rethink this.:rolleyes:
  13. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Yeah, you definitely can't have the sway bar in the stock location with crossover. I say ditch the sway bar and deal with it.
  14. AllamericanK5
    Feb 2, 2005
    131
    Colorado
    yeah we dont need no stinking saybar lol MTMike were what gears do you have in that 10blot and are you here in colorado???
