some ?'s about oil change..
Discussion in 'The Garage' started by bryguy00b, Apr 14, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    some ?\'s about oil change..
    ive only done it a few times so bair with me lol..
    i dunno what kind of oil is in my truck cuase i havnt changed it since i got it...dont worry...ive only had it a couple months..lol. does 5 quarts of oil sound about right for a change? and would it be ok to put in a different kind of oil..than whats already in there? i was thinking about the quaker state 4x4 syn. blend..?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: some ?\'s about oil change..
    Well yes 5 quarts is what a standard Chevy V8 takes. About 4 if you don't change the oil filter. I wouldn't recommend mixing oils. I haven't heard anything bad about it I just really wouldn't mix multiple types and brands of oil something wierd about it in my head. Why would you need to mix different kinds if your doing a full oil change?
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    5 quarts is about right with a filter change too. You can put whatever oil you like in it, but try and stay with the same oil on the changes afterward also.
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    no thats not what i ment..i am doing a full change..but i dont know what kind of oil is in it at the moment. i just was wondering if it was ok if i put a different kind of oil in it..with a full change yes of course lol. why does it take more when you change the filter?
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    i would think it would be obvious, the filter alone holds about a quart of oil(a larger one).
  6. Grim-Reaper
    7,385
    Atlanta
    Yeah you can change brands and weights when you change the oil. Just watch out for the weight. In Ny durring the winter you may want to run a 5w-30 so it will run a little better in the cold. in the summer you may want to run a 10w-40. Many GM engines recomend a 10w30 or a 5w30 year round because they run a AUX oil cooler. If your truck has a factory oil cooler then stick with the recomended weight.
  7. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    not to get off topic, but is the cooler on the back of my radiator a tranny cooler or an oil cooler?
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I don't know about you guys, but mine takes 5 1/2 to 6 when I change mine, and it's stock. Buy 6 quarts to be safe and go with a synthetic blend if you want, normal oil works just as well. Fill up your oil filter with oil before you put it back on, it will help lessen damage to the engine while the thing builds up pressure after the oil change.
  9. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    A good way to tell would be to check if the lines come from the tranny or the engine.
    Trey
  10. Grim-Reaper
    7,385
    Atlanta
    If it's driver side it's engine and passengerside is tranny.
    I thought the AUX tranny was a given on 3/4 ton burbs....I have a aux electic fan after all....Nope...no Aux tranny cooler on a 454 burb. Has the oil cooler. My POS 95 Vandura with 700 R4 had both but my 8600 GVWR sub doesn't. /forums/images/graemlins/rolleyes.gif It will have one by the end of next weekend.
  11. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Same here...
    Valvoline Maxlife 10w30 in the winter/ 10W40 in the summer
    Fram Oil Filters (I think its PH5)
    5.5-6 quarts with an oil and filter change
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    same here, 5.5-6 quarts for me too. I have a GM gr 350 crate motor.
    AFA mixing oils, I dont think its a big deal. I mean, when you drain oil there will always be residue of that oil on parts etc when u add the new stuff... so unless you have the system flushed or something, you're always "mixing" oils to some degree. Switching brands isnt that big a deal either. Thats just my opinion.
    j
  13. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I wouldn't think mixing oils would be a big deal either.
  14. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well i got 5 quarts of quaker state 10w-40. and a fram filter. and i came up about a quart short when i checked the oil...guess its more like 6 for me. ganan run over tomorrow and throw another quart in. also got a bottle of that STP fuel system cleaner just to see if it makes any difference...
  15. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I put 6 in mine. Mixing brands doesnt mater its the weights that you shouldnt mix,
  16. Grim-Reaper
    7,385
    Atlanta
    Same here...
    Fram filters are Junk. You know that start up rattle you have.....Fram Sorry anti dranbac valves that don't seal. Use A/C or Bosch. A/C and Bosch are the same filters with different lables. Yeah I can prove it at least on the size that fits our trucks.
  17. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    PH5, I dont believe has a drain back valve, my dads 88 pickup uses a different filter and it does have the drain back. I have used fram for well over 50K miles, and dad always uses ac filters in his 88 & 97's (maybe because of the drain back valve /forums/images/graemlins/confused.gif).
    I have a new PH5 filter in hand and I'm shaking the he!! out of it and its not rattling?
