Some thing broke any suggestions
Discussion in 'The Garage' started by earl87gta, Sep 10, 2003.
  1. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    I was out playing in the mud today and one of the guys got stuck and I have the biggest truck so I was volunteered to pull him out. It shouldn’t have been a problem I had been in 4hi most of the day when I went to pull him out I put it in 4L and went to pulling then I had a big pop and the truck stopped moving forward I thought maybe I broke a universal joint or something on the front axle that’s ware the sound seemed to have came from I got out of the blazer and every thing looked ok so I went to back up and take the rope of so I went to put it in 2w to see if it would move and nothing happened so I then put it in 4h and ever thing worked I even pulled the guy out . I got the struck back on the black top I put it back in 2w and it did not moved so I had to drive it in 4h to get it home and it didn’t like that to much made a lot of noise I only had to go about 200 yards to get it home so it wasn’t a long trip or any thing Any one have any Ideas with what’s going on with my blazer. . I guess my transfer case has a problem if I put it in 2w or 4L the rear does not move if it’s in 4H every thing works. I don’t get it. I have a transfer case out of a doge but I don’t know if it would work with my trans or not. On a side note I have a D60 rear out of a doge truck that I was going to swap in I also have the D44 from the same truck but it has a weird mounting set up and there is no way it will work with my blazer unless I do some mods to my frame to move the spring hangers way out and I don’t think it would be safe so I know all the knuckles brakes will all change over to the D44 I’m using in the truck now my question is can I use the gears from the d44 in the doge in the d44 in my blazer or do I have to spring for new gears in one of the axles. I’m going to try and get a D60 if I can find one this week If not Ill need to do the gear change I don’t want to go with out my toy for more then to weeks it’s a daily driver all summer and only gets a little use in the winter no top get kind of cold.
    Thanks Guys
    Earl
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    sounds like something popped in your T-case. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif I don't know much about the internals though sorry.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
  4. Grim-Reaper
    7,385
    Atlanta
    Well you symptoms sound like a 203 with a busted chain but since you didn't tell us jack about what case you have...hell if I know.... My mind reading skills are in the toilet today.
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    You're slipping Grimmy, you used to be so much better at reading minds.../forums/images/graemlins/grin.gif
    Rene
  6. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    Im not sure if its a 203 or a 205 Ive got to get under thier today and take a look to see what I got.
    Earl
