Some Tranny Case questions..... Which one do i need? (or want)
Discussion in 'The Garage' started by Silver84k5, Jun 7, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    The tranny guy told me today that i had a 9 inch crack in my case, That case was just a normal case, No "K" on it
    He then proceeded to tell me that if i want to K case, i need to get one out of a 78-79, because it is a "Non Lockup case" He said if i get any other k case, then i will have to buy a Kit so he can put my parts in there.... does anyone know, the difference in a 78-79 case, instead of Later K case years?... I thought that a case was a case... Thx.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i am not sure on the years, but he is referring to a lock-up style 350. this means it has a torque converter that will lock in a 1:1 ratio w/ the flywheel to give u fewer rpm's at speed. these cases have electrical plugs on them, so just stay away from them.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I'll assume that you are using a TH350 . GM went to a lock-up version in the early eighties and the older cases ( around 1977 and older ) did not offer the thicker version with the dust cover that accepts the struts . There are differences between the cases ( lock-up and non- lock-up ) - Your tranny guy sounds like he knows what he is talking about.
    Good luck , Tom
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    so i take it, its a good idea to get those struts right?
    I had a dust cover with the two holes for the struts, and i put it on a th350 that only had 4 bolts for the dust cover, i just drilled out diff holes and ran it...
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    where is the crack?
    if the bell area look into aftermarket Ultrabell
    someone here did it.
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    how do i put an after market bell on it? The whole case is one piece.or do you mean a whole aftermarket case?
    Is it possible that the tranny was ggetting reaady to go out anyway, and it got real real hot, and that caused the crack? Cuz i Sure as hell dont have the horsepower to crack the case. i know this for a fact.
