Somebody figure this out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Jun 21, 2002.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    the truck has developed a funny habit. when i stop at a light everything is normal but once i take my foot off the brake to go it feels like the rear end is unloading or dropping about a inch or so with a low boom sound????anybody got a idea? thanks /forums/images/icons/confused.gif
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    "boom" sounds are commonly drive-line related, exp. at HWY speeds.
    In a standing start, there is alot of strain on the drive-train, everything is "torqued-over" so something might be hitting or going metal to metal.
    So
    - Check u-joints,
    - Check tranny mounts
    - Check motor mounts
    - Check exhaust routing and clearance (motor torques/lean to the Right side when under hard throttle)
    Have someone watch and listen from the side, see if they can pin-point it or "see" the problem area.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  4. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    I had the same thing happen with my Blazer. I replaced the rear shocks and it went away. Unless you already have new shocks I'd try it. Was a major relief to finally figure out what that sound was. Pretty scary huh
    Dan
  5. rebel222
    rebel222 Registered Member
    Aug 21, 2000
    58
    Louisiana
    I have the same thing happening to my truck. Maybe mine isn't as severe or it is something different. My truck kicks either when I let off of the brake, or right when I stop. Does this sound like the same problem? If it does let me know what you find out please.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Turn down the POD CD or just skip that song. (sorry, could not help myself)
  7. sapper
    Jul 11, 2001
    3,052
    NoVa
    the POD CD /forums/images/icons/confused.gif /forums/images/icons/confused.gif dude you lost me
    thanks everyone else i'll start going over those listed problems today.
  8. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    they have a song and the lyrics are here comes the boom!!!!lololololol /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Thats it!
  10. sapper
    Jul 11, 2001
    3,052
    NoVa
    <font color="red"> </font color> OH now i get it /forums/images/icons/grin.gif /forums/images/icons/smirk.gif /forums/images/icons/wink.gif /forums/images/icons/smile.gif /forums/images/icons/cool.gif
  11. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    What year Blazer? My gas tank baffle thing came loose and started to knock against the tank. Only did it on acceleration. Found out after jumping on my trailer hitch enough to make the gas slosh like crazy. Just a thought though.
  12. Grim-Reaper
    7,385
    Atlanta
    The 208 and 241 trucks are prone to that. It's usualy the slip yoke into the back of the case making the noise. GM has some special blue goo grease to hide the problem but it will come back in a couple of thoiusand miles. My 79 does that but it's shot splines in the drive shaft.
    Just make sure your u-joints are in good shape and while it's irritating it's pretty normal for trucks the age of yours.
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Grim is right. Whenever you have splines that are supposed to slide, wear and/or improper lubrication can make it "shock" when it is forced to slide while under torque.
    There are other things that could be causing your problem, too.
