SOMEBODY PLEASE!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muscle, Jun 10, 2000.
  1. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    Could someone recommend the "perfect" header for my '77 K5 4wd, 400 sm block????
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Hooker Headers are pretty good never seen them on a K-5 though, just on muscle cars, so they should work. And they are expensive!
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    The best material, at the cheapest price with the easiest installation that fits your truck....hehehehehehe
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Flowtech Afterburners. They keep your low-end torque. Perfect fit. I have more details on my website.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  5. BB454
    BB454 1/2 ton status
    Apr 2, 2000
    134
    Gauteng South Africa
    Depending on what you are prepared to spend on headers you might want to have yours built to suit your needs. None of the "over-the-counter" headers could bring in the dyno figures I were looking for when building my project and so I had these made to suit my needs. Look at the length of these headers - they boosted the torque figures way beyond any best that could be found in "otc" makes. The price turned out well in comparison at the end of the day. I know it is not a K5 but the engine is a 400 and the application is the same.....lol
    BB454
    IF IT DOES NOT HAVE 8 PISTONS - IT'S BROKEN !
  6. BB454
    Apr 2, 2000
    134
    Space goblin ate my photo - sorry here it is now.
    BB454
  7. BB454
    Apr 2, 2000
    134
    ....and the other side..
    BB454
  8. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    So Hennie were those made for the application or did they come out of a box?
    2B1ASK1
  9. BB454
    Apr 2, 2000
    134
    They were built by the young chap on the left in picture. The older gent is the Dyno-master that puts the product to test.
    BB454
  10. muscle
    May 28, 2000
    408
    Show Low, AZ
    I like how they sweep back instead of dropping straight down, then back. The problem I had with my previous set was they would get crunched by the front drive shaft.
  11. muscle
    May 28, 2000
    408
    Show Low, AZ
    Tell me more about the flowtech afterburners. Any dislikes? Do they get in the way of anything?
  12. BlazinHi
    BlazinHi Registered Member
    Feb 27, 2000
    5
    San Antonio, TX
    I used a set that are made by hooker but the name is castler or kastler. I'm not sure on that spelling. But one thing I would stay away from are the dynomax header they suck you have to use a wrench on number 3 spark plug. on the new ones clearance is better..
    Blazinhi...Blazinlow...Blaze a trail..Lets GO..
  13. Blazer79
    1,816
    I bought the Flowtechs from summitracing.com I got the Ceramic Coated ones for about $270. They were easy to install. I barely got them scratched. If you have A/C, then you have to get the A/C bracket. This was the only problem I had: I had to grind about 3/4" off this bracket because it wouldn't bolt just like that.
    After my first spark plug change, I can only say that the #8 spark plug was a bit harder than usual to change. The spark plug socket went in fine, but my ratchet would not reach it because of the headers, and the extension I had was too long and hit the frame. With the right tools, I'm sure it would be very easy.
  14. muscle
    May 28, 2000
    408
    Show Low, AZ
    ok, now i'm leaning on the flow tech afterburners. Anybody got more on these?
