Somebody Tell me I am right...
Discussion in 'The Garage' started by BlazerWheels, Jan 12, 2005.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    PLEASE!!!! I opened up my rear diff today (change gear oil) and I think I may have 4.10's instead of the 3.08 that I thought (from looking in glove box).
    Anyway, I know you are supposed to divide 2 numbers that are stamped on the ring, but I am not sure of which 2...here are the numbers as they read directly off of the ring...
    2 GM 3(could be a 5)988515 10 41 1 83(or 5)
    I think the ones in red are the two that I divide...and if so that means I have 4.10's
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you would be correct.
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if i were you, I would check that the front ratio matches.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    83(or 5) is your year stamping
    what axle model ? what year and model of truck ?
    im assuming 10 bolt,
    so 4.10 is really interesting..
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I would just count the teeth to be %100 sure, divide the ring gear by the pinion gear. :xmas:
  7. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    those would be 4.10's...no question.
    Rene
  8. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    how do you count the teeth on pinion gear with the ring gear installed?
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Clean off the end of one of the teeth and put a blotch of paint or some other mark on it. The slowly spin the pinion gear while counting teeth. It may help to stick a piece of wire in there to act as a pointer.
    MArk the ring gear teeth the same way.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    1-2-3-4-5-6-7-8-9 and so on...:D
  11. BlazerWheels
    Feb 13, 2003
    587
    California
    Year is '85 K5. Axles have not been swapped (I think) bought it from my uncle who is VERY anal retentive. So I know HE did not swap them....
    Yes 10 bolts...
    Reason I thought that I had 3.08's (until I pulled cover) was the code in the glove box. Actually says 3.08 rear axle ratio on sticker...then I pull the cover and HELLO...:D :D :D
    It also says it has a traction locker (I forgot exact words) maybe you can ID this for me...
    http://www.norcalbigdawgs.net/phpBB2/viewtopic.php?t=5993
  12. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Looks like not a Gov lock. Limited slip of some sort I guess.
    You definitely have a less common diff if it truly is as stock as you say.
    Rene
  13. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    UH OH , looks like a gov lock :screwy:
  14. BlazerWheels
    Feb 13, 2003
    587
    California
  15. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    All the gov-loc's i've ever seen have never had that big "I" chunk of steel in the center of the spider gears.
  16. BlazerWheels
    Feb 13, 2003
    587
    California
    ANy ideas then??
  17. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Have you tried looking on ebay for pics of what people have listed for sale to maybe figure it out?
  18. BlazerWheels
    Feb 13, 2003
    587
    California
    Nope...maybe I'll give that a try tomorrow...
  19. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    That thick ass ring gear is also a dead give away of other than 3.08 gears. With a stock GM stamp on it that is an awsome find. I would still check the front just to be safe.
  20. big jimmy 91
    Feb 21, 2004
    639
    It's the same as mine , a gov lock , grenade locker
    There are some crappy pics of mine in my web shots under "whats this" ,and everyone here id. it as one
