Somebody tell me that chevy didn't put these in here.
Discussion in 'The Garage' started by gotmud77, Mar 23, 2004.
  1. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    Somebody tell me that chevy didn\'t put these in here.
    I 1973 did chevy put 3" blocks under all four of the leaf springs? Its a 3/4 ton pickup. I told my buddy that they didnt do that and he should take them off the front but i just want to hear from everybody here.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Somebody tell me that chevy didn\'t put these in here.
    Most definitely NOT stock. Front blocks are way too dangerous to even consider driving around on! /forums/images/graemlins/yikes.gif
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll second that. Front blocks are a No-No! /forums/images/graemlins/yikes.gif /forums/images/graemlins/shame.gif Definately not OEM. /forums/images/graemlins/shame.gif
  4. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Blocks in FRONT /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gifThats very unsafe!Too easy to have the axle roll out from the perches! /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gifDeath trap waiting to happen!
    Bill
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/shame.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/shame.gif Blocks are bad! /forums/images/graemlins/eek.gif
  6. gotmud77
    Aug 4, 2003
    689
    bellefonte
    Thank you for the speedy replys. I would never do it and i told him chevy did not do it and he should fix it asap.
    Thanks again, /forums/images/graemlins/thumb.gif
  7. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    arent zero rates blocks?
  8. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    zero rates bolt to the spring pack with the spring pack bolt....in effect making them just a really really short leaf.
  9. tecton
    Dec 1, 2002
    1,553
    WV
    ok
    couldnt you make a 3 inch zero rate?
    or bolt blocks the same way
  10. ColAdo82K5
    Feb 18, 2000
    789
    MO
    Have you ever seen a 3 inch thick leaf ? nope. That tall block creates axle wrap. Having the 1 inch zero rate really doesn't add any real wrap, and by being bolted to the pack, it's not going to fly out...and if it does, you have bigger problems.
    Tall blocks "could" be welded or bolted into place but the axle wrap would still be the issue. That wrap can break the leafs springs in many cases.
    Blake
  11. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Blocks, you see now, blocks are bad mmmmmmmkaaayyyyyy?! Cuz on account if you're usin blocks on the front you could, you could cause an accident. Cuz blocks are baaaad, mmmmkkaaaayyyy???!
    Just thought I'd doctor it up a bit.
    Good luck to y'all in the future.
    Allan
  12. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Tell your buddy to get those blocks out ASAP. Especially if they are aluminum, because with even mild wheeling the tit will sheer off, spit the block out, buckle the front end over and customize his fenders and doors. /forums/images/graemlins/doah.gif
  13. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif he said "the tit will sheer off".. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Seriously tho', blocks in front are a big no no! /forums/images/graemlins/shame.gif
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yes zero rates are blocks
    spring center bolts break all the time
    some put a lot of faith into a 3/8" unrated bolt because it is sold by ORD
  15. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    hah... front lift blocks are the devil.. but check this out.. at the dealership i work at.. we have an "accessories" department, and you guessed it, they install front lift blocks in superduties, toss a set of 35" bfg a/t's on it and mark it up 5 or 6 grand.. no matter how much i tell management its not safe, and probably illegal, they continue it, so once someone gets hurt and we get sued, ill have a new job as a "sir" aka management! /forums/images/graemlins/dunno.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It is a grade 8 bolt, although I agree with you, I'm not sure exactly how I feel about having one up front yet.
    We shall see.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I was just looking at a stock centrebolt, no idea what ORD sends
  18. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    has anyone seen or experience a front block break away from a front axle? i am curious and want to see pics.
    i agree blocks u front are a bad thing, but i do have zero rates currently without any issues on my front axle.
  19. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have to agree here, I have sheered a couple, but regaurdless if you have a centering pin in a pack or a 1 inch zero rate you are still pretty much screwed. As soon as it fails the axel can slid back causing the wheels to lock at a full right turn /forums/images/graemlins/yikes.gif
    The 83, when it hit the pomtree had the same effect,I see the zero rate as a plus though if you moved the axel forward as it has a pin for the pack and a short pin for the zero rate to stay in place.
    as for not moving the axel, if the pin breaks the zero rate can pop out, then you have a serious amount of movement, compared to a stock set up where the u-bolts might help ya out /forums/images/graemlins/thinking.gif
    at any rate it was one scary situation in the 83 /forums/images/graemlins/tongue.gif
  20. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Many of the Ford factory blocks have cast-in eyelets that the u-bolts pass through and an enormous tumor on the side for a bumpstop. Fat chance these things ever slip out.
