Someday I will win over that mountain (vid)
Discussion in 'The Garage' started by Ronnie4wd, May 14, 2006.
  1. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
  2. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Man, you almost had it. Looks like on one of your running start tries you had good momentum but your rear bumper scraped and you lost some of it. I was rootin for ya. That hill (it did look like a borderline mountain) looked kind of sandy and loose. Those kind of hills suck. You'll get it eventually.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I dunno, kinda looks to me like you get a little running start, and then let out of it half way up,,,,,,,,,,
    GAS ON IT !! and keep it goin
  4. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    sounds like your not giving it any gas man. 2nd gear to the floor let that motor scream
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, what they said! i didnt even see rooster tails or flying debris!
  6. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Lock the front and mash the skinny pedal!!!
    Also what's the tread look like on your tires?
  7. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    Just put it in 4LO, and walk up the hill. WTF
  8. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Wanta borrow my Toyota?:D
  9. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Its not a flodding Rochester, or a slipping clutch. Not enough grunt?
  10. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Looks like it was just losing traction at the top...
    Rene
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What I was thinking . It looks like a very good surface for traction . 4xcrazy and I cut our teeth on steep stuff like that when we first got our trucks . Only thing different is we had open diffs and gov locs , all terrains , and highway gears ............. and loose dirt :D
    NO offense to the parties involved , I just KNOW he could make it .
  12. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I don´t have any more power and would need other gearing can´t afford any now :mad: .
    The gravel at the top will soon be down the hill so it will be clean then I will win ;) .
  13. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    Here's a couple of pictures too. Look at the rear tires. It's nothing wrong with the grip, just needs more power:D
  14. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    22:1 crawl ratio doesn't help...:doah:
    Rene
  15. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Naw, I think your 6.2 alittle tired. Foot-to-the-floor in a high load situation I would expect to see a bit of black smoke. Time to "turn up the wick" :D
  16. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Yes I´ve been thinking about that since I bought my first 6,2 and since then (2000) I´ve seen several of 6,2 engines, not mine, gone bad and all of them were "turned up".
    But the difference now is that this is not my DD anymore so turn it up a little couldn`t hurt :crazy:
    How much would you recommend :dunno: for a trailrig who sees very little street.
  17. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Ideally the pump needs to be timed electronically first. The "hash" marks on the pump and mount are only ball-park marks to get it running. I've adjusted the pump around and a timing gauge will tell me the pump is several degrees off, when my eyes tell me the pump alignment hasn't changed :doah:
    Turning up the fuel delivery is a tricky thing with-out an exhaust pyrometer to keep you out of trouble. That said, a heavy climb like that one should produce "alittle" black smoke without cooking the motor (I hope :o ). -Like an 1/8th or less turn.
  18. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    This is why I like sticks, either you have the power or you dont no torque converter slipage.
    I heart my GRANNY GEAR!!!
  19. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,023
    849
    Pinckney, MI
    I'm swaping to a stick as soon as I can find a good 32 spline 465!!! I cant wait to have a decent crawl ratio, not to mention decending down hills are alot easier :)
  20. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    when I rebuilt my 400 I put in some red eagle clutches and koleen steels a shift kit and stack plate cooler, so the tranny never fails to hook up and turn the wheels.. you may want to put your np208 back in there and save up for a doubler, 2.61 is a little better than 2.0
