somekind of posi,or limited slip up front????
Discussion in 'The Garage' started by down4thakrown, Oct 12, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    as i was climbing a pretty good size hill i snaged the wall i was goin up and broke my front axle but, i had all 4 tires spinning until my axle broke then i lost all four wheel drive. anybody have an idea what kind of limited slip or posi i have.cuz there was no action coming from the front after the one side broke????? i also have slugs in the front. /forums/images/graemlins/whistling.gif
  2. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    u sure it was a shaft snapped? and maybe not the carrier/gears blew up?
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i dont think so cuz when i turn the drive shaft by hand the i can see the two axles trying to turn the same direction
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sounds like you have nothing, and were simply on a high traction surface.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i agree, sound just like my open.
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i guess i'll have to pull the cover to conferm, when i bought the truck it came on the guy said it was a trutrac. /forums/images/graemlins/dunno.gif
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    This is very typical of almost all limited slips. If you break a shaft it's even worse than having one of the tires completely off the ground, and most limited slips can't overcome that much of a difference in traction/resistance. The inner part of the broken shaft is probably spinning, but it's no longer connected to the tire.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Agreed.
