Someone have a '90 or 91 wiring diagram?
Discussion in 'The Garage' started by dyeager535, Aug 28, 2004.
  1. dyeager535
    26,982
    191
    Someone have a \'90 or 91 wiring diagram?
    I'd appreciate a scan of it.
    Thinking about my '91 205/electric speedometer swap, and realized that the DRAC may not work with the ECM I have.
    Anyways, I'd like to see how the DRAC was wired, as apparently some ECM's can interpret the raw data from the speed sensor and output that to a speedometer or cruise.
    Might make it easy if I can wire around the DRAC, but if not, going to need to know how it was setup.
    Thanks!
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Someone have a \'90 or 91 wiring diagram?
    Dorian, try here and see if there is anything you are needing.
  3. dyeager535
    26,982
    191
    Nope, but thanks though. Doesn't cover any of the insturment panel or t-case stuff. /forums/images/graemlins/frown.gif
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think you will end up with an uncalibrated and unbuffered signal at your ECM. /forums/images/graemlins/thinking.gif
    Either ECM (87-89 or 90-91) should take the same 2-pulse input. The difference lies in where its generated. For 87-89, the signal is derived at the mechanical speedo in your dash. For 90-91, the signal is derived from the DRAC, which converts & calibrates the 40-pulse signal from the VSS.
    I'm kind of messed for time, but if you have a specific wire color or pinout question I can reference it somewhat. My '91 still has the wiring and ECM in it even though the 350 is long gone /forums/images/graemlins/whistling.gif
  5. dyeager535
    26,982
    191
    Some of the later Camaro ECM's use a 4 pulse system IIRC. According to one thing I read, some Camaro ECM's are set up to do all the DRAC's job internally...tire or gear change modifications to fix the speedo are done through the PROM. (Sweet!)
    I guess I don't have a specific pinout question yet, except unless you can scan a pinout of the DRAC itself. I'd like to know how it's tied into cruise control for instance. I'm sure it just goes straight to cruise module (or ECM 90-91??) from the DRAC, but I need to know what I'm dealing with before I go planning my next step.
    I'd rather not convert to speed density yet, but looking at the DRAC, it looks like I'll be doing a lot of re-wiring anyways.
  6. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Im gonna get on to scannin that stuff tonight Dorian... /forums/images/graemlins/waytogo.gif
  7. dyeager535
    26,982
    191
    I appreciate it!
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Here ya go Dorian, I posted in here so everybody else could have access if they wanted... Wiring
