Someone have a..
Discussion in 'Southeast Region' started by 79Stomper, Oct 27, 2006.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    NP 208 laying around or going to have one laying around in a month or so? Don't need it exactly yet but will before too long. Need it to be splined for a TH350. I got to looking at Thumper today and noticed a few bolts loose on the T case and well one fo the hole was stripped so I found out why one was loose.
    I can tolerate the leak for a little while but not for to long though. \\BT
    TIA
    James
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Is there anyway to helicoil it?
  3. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    I have one in the corner of the shop. Was in my blue K10. I may let it go. But it was behind a 700R4.
    Clay
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Should be the samething. Both are 27spline.
  5. Bushwhacker
    May 13, 2002
    796
    Both are 27 spline , but the 700 has a longer tailshaft. I think you just need to swap the adapter as well for a 700/208 adaptor instead of the 350/208.
    Clay
  6. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I thought that the TH350 with NP208 you had to change the shaft in the TH350 and use a spacer. The adaptor was the same. I try to remember and look tomorrow.
  7. Bushwhacker
    May 13, 2002
    796
    I have heard some cut a little off the 700 shaft and use the regular 350/208 adapter cause its thinner than the 700/208. Or use a 350 with the spacer and 700/208 adapter. Something to do with the adapters, and the 700 shaft sticking out farther. Both ways can be made to work its just a matter of mixin the right stuff. Go investigate and holler back! you got me wondering now:D :doah:
    Clay
  8. jayweb
    jayweb 1/2 ton status
    Jul 6, 2003
    213
    NC
    I'll have one available as soon as I swap my 241 in - should be within the next couple of weeks. (I'm in Sanford, by the way, and the t - case is behind a 700)
