Someone learn me about dana 70 pinion offset
Discussion in 'The Garage' started by mofugly13, Jul 26, 2006.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    What is the physical difference between a dana 70 carrier for a case with a 5/8" offset and and carrier for a 1/2" offset?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Maybey think and thin gearsets. If there is such a thing for a D70
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I would like to know this as well, I have done a little bit of reading and havent seem to found anything talking about what the "pinion offset" is. I dont know for sure but I think that it doesnt have anything to do with a carrier break, only because in gear application catalogs it lists different offsets for dana 70, 70U and 70HD :dunno:
  4. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
  5. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Good link, this post jives with what I have been told.
    http://www.pirate4x4.com/forum/showpost.php?p=5736451&postcount=10
    But I have a powerlok carrier at home, when I run the numbers in the Dana spec. book, it says that it is a D70-B with a .5" pinion offset, but this carrier is from a mid 80's truck, and .5" offsets are pre-'71, according to the chart. I want to put it in my D70-U with a .625 offset. I have been told by numerous people that it will go, but I dont want to pull the old carrier out, swap the gears over, and then find out it's not going to work.
  6. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Mofugly - Once you have the carrier's out measure the ring gear flange's and compare before you go any further and that should answer any questions.
    To the best of my knowledge the carriers change over between the .500" & .625" housing but the 70HD-3 might be different animal if you have parts from one ???
    Tom
  7. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I dont have any D70-HD parts. I have a powerlok rebuild kit and need to know if the carrier will work befor I go ahead and rebuild it. If worst comes to worst, I'll take the open carrier out and measure it against the one I want to use, but I'd really like to have the rebuilt powerlok ready to go before I pull the open carrier out.
