Someone parting a truggy - - should I take the axels?
Discussion in 'The Garage' started by m1ndless, May 3, 2007.
  1. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    http://phoenix.craigslist.org/pts/324000398.html
    "-4.10 geared 3/4 ton front and rear axles, the front is a shaved 10 bolt with a limited slip and 4.10's. has BRAND NEW warn premium locking hubs and a raised steering arm... the rear axle is a 14 bolt Full floater that has been spooled.. Done professionally by a welder friend of mine... stil has the massive drum brakes and everything works fine... Asking $600 for the set or $500 if you help me pull them out... ":
    Yay or Nay?!
    I might take those headers too.
    Should I just get a quick loan, and buy the whole damn thing? I would use parts from my current 79 or vice versa?
    Suggestions???
  2. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Anyone?
    Is that a good deal on the axels?
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Dude, Nate is a member on here as you might know. Go look at the truck if your interested in the whole thing or parts.
    Harley
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    when I see "professional welder" I think welded rear instead of Spool. why would a welder install a spool? I would want a mechanic to install a spool, preferablu one that has done gears before.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Welded or spooled it acts the same. I believe it is welded but same difference if they are welded right.
    Harley
  6. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    to much in my book. i got my 14ff for free, welded it myself (i am a professional:wink1:) and it came with 4.56. i was given it, but it was originally bought for $50 by my dad. did i mention it is from a van, and 3" wider?. anyway, i see 8 lug 44/10b for anywhere from $100 to $300 all the time. hell, if you are patient, good things will come. my buddy got his D60 for free, and it came with a warn winch bumper and a 8274.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Marv welded that axle , so its good . We all ( AZ ) trust Marvs welds .
  8. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    i wish i had the money for that
  9. 87K506
    87K506 1/2 ton status
    Sep 18, 2005
    536
    Pitkin, Colorado
    I'd stay away from welded rear/spools if you drive it on the street at all...Granted in a 14bff it wouldnt break but your tires will wear faster.
  10. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    only if you turn:wink1:
  11. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
  12. 87K506
    Sep 18, 2005
    536
    Pitkin, Colorado
    TRUE!!! build your blazer big enough with bigenough tires and you will never have to turn, just drive over or thru anything in the way
  13. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    First I bought my axles (same as yours, 4.10 , 3/4 tonners, D44HD front and D60 rear) for 100 bucks for the pair, plus the guy threw in a dana 24 Tcase. I paid 400.00 for two spools, 120.00 each for new R & P's, 100.00 for two sets of new bearing kits, 400.00 per axle for hardened shafts and joints and then 300.00 to have it all installed in the axles...almost forgot the 150.00 to cut off the Balls on the end of the front axle, and have them welded back on with 15 degree caster.
    No one said it was gonna be cheap!
  14. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Well, I don't do much turning. :)
    So should I talk to him about the axels? How much faster do the tires wear?
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you drive your truck on the street much you will not want a welded/spooled rearend. I ran one for 2 years in my K5 and it ate up MTR's like no other. It is a fine option for a trail rig or non-DD truck but if you put decent miles on your truck then you won't want a welded.
    Harley
